All -
I cannot for the life of me get the pilot bearing out of the crank... I have tried everything in the FAQ:
At this point, the only other options I can think of are a) heat up the crank around the bearing with a torch or b) dremel tool and carbide bit to cut it out.
Any other options I should consider or do you recommend a or b above??
Front of blown out bearing:
Slide hammer:
Carriage bolt puller... note the bent bar stock and bent carriage head:
- Tried the bread and grease tricks.. It blew out the front of the bearing allowing bread to blow through the bearing
- I made a slide hammer (see below) - nada
- I made a longer one - nada
- Made the carriage bolt puller - it bent the bolt and a 1/4" piece of bar stock - nada
Slide hammer:
