Cruisers and Co
Supporting Vendor
- Joined
- Mar 30, 2023
- Threads
- 3
- Messages
- 424
- Location
- Westminster, Colorado
- Website
- www.cruisersandcompany.com
Do it, Wes is awesome!Oh man thx! I would love to take you up on that offer!
When the time comes it's easier to pull the whole throttle body, then pull the IAC off from there. Cleaning the IAC passages in the throttle body, doing the FSM tests on the IAC stepper motor, and dialing in the TPS settings as well as the throttle cables helps a lot in the drivability of these.EGR is fixed. New issue has cropped up:
When AC is on car will nearly die when I hear an audible relay click in the cab. I am guessing that is the ac turn off and on to prevent freezing. Need to find a few hours to pull the IAC I think to make sure it is not gummed up
right now the car comes in at 6034lb with full tank of fuel and me in it. I have bumpers and platform planned. that _should_ put me at 7K-is pounds. Sorry I wasn't super clear on that.Try keeping the weight down with mods. 7-8K pounds is a lot more than stock.
When you say it feels like the truck is tearing itself apart at 60 mph, does that mean the engine is straining or the truck is shaking?
A healthy 80 should easily hold 75 mph with a smooth ride on relatively flat ground.
I think you are right that the last thing I need to fix for idling issues is the IAC. I know for a fact the TB is completely gross on the inside and needs a cleaning. I just need to bite the bullet and do it.When the time comes it's easier to pull the whole throttle body, then pull the IAC off from there. Cleaning the IAC passages in the throttle body, doing the FSM tests on the IAC stepper motor, and dialing in the TPS settings as well as the throttle cables helps a lot in the drivability of these.
After doing all of this on mine the idle is spot on at 650rpm and adjusts as it should when the AC is on.
This is completely normal 1000-1200 rpm for a little bit then down to the standard 650-700 at idle.On a cold start mine revs up and will eventually return to idle. I'm pretty sure this is normal.
I’m just guessing, my truck usually does 1100-1200 on cold start. Just a read a few post 14-1600 seems pretty normal also. Gonna check the FSM to get a solid number. Lots of guys saying vacuum leaks causing 18-19-2000 on cold idle starts and fixing all the vacuum leaks lowers those numbers quit a bit.@Fj80oregon beat me to the punchand probably with the right number
Did they also tint your windshield with Ceramic tint? Place I went to wouldn’t do the windshield while it was still on the car.Ceramic pro services east did the tint for me. Did really good work IMHO. the first photo was original tint. The current tint is in the photo attached. the tint makes a world of difference. Interior temps are down, and we do not get burnt in the cab anymore.
The tint is: Ceramic IR. it is a little darker but def in the legal limit.
This makes me think I still have a few leaks to tackle.When i had vacuum leaks, mine would cold idle at 1800rpm. Very annoying!
It took some convincing, but yes they did the windshieldDid they also tint your windshield with Ceramic tint? Place I went to wouldn’t do the windshield while it was still on the car.
