Can't be tight if it's a liquid
He probably just saw the sway bars and assumed….I got my Land Cruiser back from the shop today and the air-conditioning is blowing ice cold air! I stopped for fuel and someone came over and asked me if I had a slip yolk eliminator kit installed. I told him that it wasn’t a jeep and that it didn’t need kits to eliminate weak components. Perhaps I was in a grumpy mood. Ha. We still talked for 30 minutes.
Yes he did, and he wanted to know if I have upgraded those with disconnects.He probably just saw the sway bars and assumed….
You bet…though they are buried. I’ll snap a few pictures tomorrow.If you get a chance post some ac line pictures.
Here are a few. They moved my fill port to behind the headlight as the area around my compressor is too tight to connect the machine.No rush. Thank you!
Looks like it flex’s wellShakedown #2 was a success! We went to Bill Moore Lake today, which is pretty close to Spring Creek so it gave us similar terrain as a few weeks ago with better scenery.
It was HOT today, which really put the Cruiser to the test. The PSC assist is amazing, and the cooler and remote reservoir kept the fluid from boiling over. The steering is a lot more precise and stable on the road, and it has more than enough power for me off road. We had a coil spring come out of the coupler so I will need to add a bit more preload. Other than that I am pretty much ready to hit the road.
The AC works VERY well! It sure does make the engine run warmer. We hit 227 climbing hills with the AC on high and the LS seemed to like that temperature. It didn’t overheat like my 383 did at that temperature.
No doubt. I haven’t found a rock large enough to make the tires lift but it seems like the suspension is working like it should. It’s fun to drive. Those pictures are of my friend giving it a go.Looks like it flex’s well![]()
Thanks! You can get a dual band radio. I have one but I haven’t installed it yet. I have a Rugged Radio RDM-DB. The antenna is from Alamosa Antenna and it is tuned for UHF, which is what I plan to use to communicate with GMRS/FRS radios. I don’t have a VHF antenna yet, and I won’t get one unless I start volunteering for search and rescue.Looks awesome Mike!
Just noticed the antenna, what radio and antenna are you running? I have some baofengs to get by for now but worried about hearing them, would love a HAM/GMRS combo but don't think that exists.
Some of the information above may be incorrect and I am speaking with a different representative at rugged radio as I type this. Standby and don’t purchase anything based on what’s written above.Thanks! You can get a dual band radio. I have one but I haven’t installed it yet. I have a Rugged Radio RDM-DB. The antenna is from Alamosa Antenna and it is tuned for UHF, which is what I plan to use to communicate with GMRS/FRS radios. I don’t have a VHF antenna yet, and I won’t get one unless I start volunteering for search and rescue.
I’m new to amateur radio so check your facts. I had some help from Rugged Radio to pick the right unit for my use.
RDM-DB - 50W Dual Band UHF/VHF Mobile Radio
The RDM-DB powerful digital mobile radio delivers digital technology for superior, clear communication using digital technology. The difference between signal quality in analog vs digital is huge. While both an analog & digital radio will transmit over the same distance, the digital radio will...www.ruggedradios.com
Great example of the sway bars at work, keeping you level.Shakedown #2 was a success! We went to Bill Moore Lake today, which is pretty close to Spring Creek so it gave us similar terrain as a few weeks ago with better scenery.
It was HOT today, which really put the Cruiser to the test. The PSC assist is amazing, and the cooler and remote reservoir kept the fluid from boiling over. The steering is a lot more precise and stable on the road, and it has more than enough power for me off road. We had a coil spring come out of the coupler so I will need to add a bit more preload. Other than that I am pretty much ready to hit the road to Creede.
I am not too up to date on radios. I have a few of the Boafangs (sp) for rec wheeling. I have a 50w radio in the race car and hand helds but it is not the same, may be uhf or vhf. I am usually the monkey behind the wheel. If I am on the radio, I am not winning! lolRugged Radio has pretty amazing customer service. Although the RDM-DB does have frequency capabilities that span Ham, GMRS and FRS, they come pre-programmed with unique business channels used in the racing industry and they do not include any pre-programmed frequencies for ham, GMRS or FRS. I bet that @matzell will be able to provide better information in that area? I was told that the FCC does not allow radios to come pre-programmed to transmit on both ham and GMRS/FRS frequencies. Although the radio that I purchased is capable of transmitting on those frequencies, you cannot program those channels with the handheld itself and I would have to program it using a computer and software.
It looks like @Ditcherman was right. Thanks for sharing that above. Your comment made me double check my logic.
Thanks. I’m quite impressed with these bars. It takes a large amount of lean out of the equation.Great example of the sway bars at work, keeping you level.
Haha! Let someone else do the communication and keep your eyes on the road!I am not too up to date on radios. I have a few of the Boafangs (sp) for rec wheeling. I have a 50w radio in the race car and hand helds but it is not the same, may be uhf or vhf. I am usually the monkey behind the wheel. If I am on the radio, I am not winning! lol
Oh yea, my blind squirrel has a broken clock! Or something.Rugged Radio has pretty amazing customer service. Although the RDM-DB does have frequency capabilities that span Ham, GMRS and FRS, they come pre-programmed with unique business channels used in the racing industry and they do not include any pre-programmed frequencies for ham, GMRS or FRS. I bet that @matzell will be able to provide better information in that area? I was told that the FCC does not allow radios to come pre-programmed to transmit on both ham and GMRS/FRS frequencies. Although the radio that I purchased is capable of transmitting on those frequencies, you cannot program those channels with the handheld itself and I would have to program it using a computer and software.
