so will the later steering box work with a few mods?9/72 (73 model) was when the steering column change with a coupler between the steering column shaft and steering box. Earlier shaft was part of the box.
Besides the pedestal the opening firewall had a bracket to secure the steering column tub. Previous years tube was secured at the steering box and bracket on the bottom of the dash. Those just as a flexible rubber seal at the firewall.
A '73 steering box and column with a rag joint fit my '70 fixed column with 3 on the tree frame mount just fine--if that helps.
How did support the column at the fire wallA '73 steering box and column with a rag joint fit my '70 fixed column with 3 on the tree frame mount just fine--if that helps.
