Need help! The LC will start and run great for about ½ hr to 1 hr during that time I can drive it, accelerate the engine, turn it off and back on. Everything works great then it just dies. It will start back but then die. After it dies and stays off for 10 minuets it will start and run for about 10 minuets. If I let it sit for a long time it will start and run for ½ hr to 1 hr. Whenever it starts dying no change even if I pump the gas peddle.
It is a late model 77 no modification just like page 271 in the Haynes repair manual.
No vapor lock on the gas tank, I have taken the gas cap off no change.
All new vacuum lines correctly installed checked and double checked.
I drained the gas tank and changed the fuel filter. Fresh fuel with a new inline clear fuel filter, Fuel is present in both the filter and the carburetor bowl.
Disconnected the BVSV vac. line no change.
Disconnected the EGR vac. line no change.
Before I start swapping parts trying to figure it out, has anyone had experience with this problem?
Wondering if it could be the ignition coil and or igniter is getting to hot and miss firing.
