Yup placed my order asap. $19 shipping to california was interesting..Just got an email saying slee had them in stock.
There may be other model Toyota lines that are longer than stock 100 series lines and will fit on 100s (sensu CDan’s and Wits End’s kits for 80s), but I am not aware of any. Aside from nukegoat and others who have done SAS, it seems rare for anyone to need extended lines on 100s, given there’s not much that can be done to demonstrably increase travel of the torsion bar front end. Consequently, not much of a market for extended lines on 100s, as @Somebodyelse5 noted.Sorry, extended I mean. If so part number?
Same shipping to Idaho, for a large envelope.Yup placed my order asap. $19 shipping to california was interesting..
There may be other model Toyota lines that are longer than stock 100 series lines and will fit on 100s (sensu CDan’s and Wits End’s kits for 80s), but I am not aware of any. Aside of nukegoat and others who have done SAS, it seems rare for anyone to need extended lines on 100s, given there’s not much that can be done to demonstrably increase travel of the torsion bar front end. Consequently, not much of a market for extended lines on 100s, as @Somebodyelse5 noted.
Doing things I don’t need to do is my specialtyBut for the same old lift nearly everyone else is running, you don't need extended rear lines.
I'm trying the "shotgun" approach to the 99 LX pedal, that feels nothing like our 00 LC, or 06 LX. Have a MC rebuild kit, Slee brake lines, and plan on a front brake job, to try and address the issue.
My opinion is about and valuable as gum on the ground, but I cannot recommend this kit. I bought the 98-99 non-VSC kit. Happy to sell it to someone since Slee won't take it back, but for the reasons below, I'm not installing it on my vehicle.
First, one of the fittings uses an 18mm head. For a company that "has their stuff dialed in", I just don't want to carry another wrench.
Second, the clips that retain the 18mm headed fitting into the back of the hub on the tab are very tough to remove, like 10x times harder to remove than the OEM clip. Now imagine if any of it become rusty..you'll just have to cut it off.
Third, the copper gaskets that they provide get stuck on the bolt and cannot be removed without damaging them and possibly the bolt. It's either the fitting they use or the gasket, or both, but it's not right and it's not as serviceable as Toyota-designed parts.
Fourth, the banjo fitting elbow does not route through the notch provided by Toyota on the caliper. I see two issues with this, with one being that Slee's routing lets the line hang out more with a higher risk of catching on something and being damaged and the other is that it allows the fitting to creep while tightening it.
Hey @JunkCrzr89 buy these and throw in an extra $3 18mm socket
18mm wrench*An 18mm socket won't get you anywhere with a stainless brake line in the way. Open ended, flare nut, or adjustable needed. It's just needless complication.
18mm wrench*
Here, I just simplified your entire tool box:
Amazon product ASIN B005EXOK22
I dont remember needing an 18mm wrench when I installed the Slee braided lines. Remind me which fitting is larger than all the others?
FYI The copper sealing washers are single use, and so are the toyota sealing washers.
I used this exact kit and have no issues....
- Those clips are harder to remove, but if you are clever with pliers it's no big deal.
For the clips, if you put the upper curved jaw of your channel locks on the edge of the bracket itself, and the lower jaw on the bent edge of the clip, you can roll the pliers in the direction of the bracket which will create enough leverage to easily pull the clip out. It's hard to explain but easy to do, especially with a little PB blaster or WD40 on it. The clips are supposed to be very snug, but maybe yours were much more snug for some reason.Again, a 18mm socket isn't the right tool. I am also not stating that I had issues installing. They went of "fine". After installing one side, I summed up needing an 18mm wrench, the line isn't routed where OEM goes, and the retaining clip needed more than pliers to install, and decided this wasn't as good of a kit as I was hoping for and for the exact same money I can get Toyota flexible lines.
Being clever would not have helped the situation with the clip on my removal. It was unjustifiably tight in my case. A slide hammer with vice grip attachment would have helped.
Have you tried to remove one of your clips yet?
