Thought that was you. I would think the jdm one is stupid rare and expensive. I'm happy enough with the Amazon universal bottle. IF it breaks its easy to get a new one in 2 days. LolI have that in my SC’d truck
Link me please to more info. I would love to do that. Actually I would use the factory bottle for the Meth kit.There is an added step of relocating the charcoal canister and fuse block if you want to use the left fender washer bottle. Landtank back in the day made a bracket to relocate the canister and you can still get the factory fuse block mounting bracket...but I don’t think the charcoal canister bracket is available anymore...would need to fab something up.
if brackets are still available I could turn on the CC mounts again.
Part Number: 82615-60010if brackets are still available I could turn on the CC mounts again.
Here you go...oldie but a goodie.Link me please to more info. I would love to do that. Actually I would use the factory bottle for the Meth kit.
Then I move this Amazon washer bottle back to the left side upper pass corner.
It doesn't all happen over night. At least for most unless you're loaded and pay for labor!I'm still 5 steps behind.. while I am staring a new job and finishing up the suspension, and interior, and bumpers/sliders.
Good news I suppose is that y'all will have this all dialed in when I'm done. Wish I got in the 80 game sooner,
You got the part number for both of the tanks? Are they still avail new?Here you go...oldie but a goodie.
Another Washer Bottle Solution
Looks like inside fender is discontinued
JAR ASSY, WINDSHIELD WASHER
That is correct
Can figure that out on Monday and let you know. Might need a reminder though!Do you know how much your tank holds? Looking like it’s going to be my best option.
Amazon bottle works in the same spot as @Briano. Used a spacer and a longer bolt for the bracket. Its a really small bottle but its better than zero washer fluid. This will work for Dual battery turbo owners.
Strong. Im using Tundra 2006 nozzle sprayers which are a great upgrade. Flat spray pattern and wide enough to reach end to end on the glass. I hooked up only one fill motor(front) and Teed off the rear. Sprays all 3 nozzles with no issues at the same time. I'm going to rehook everything correctly today using the oem rear sprayer motor for independent function.Thanks for the info on this washer bottle. Is it also half gal cap and how strong is the pump? I have 4runner sprayers and the original pump doesn't have enough pressure for the extra holes in the nozzles.
Could you provide us a faraway pic of this area please?
Thanks.
ps I just rebuilt my PS pump and hoping like hell it'll do the trick!!
It doesn't work as well sideways. I'm going to test it out some more. I might bend it the other way or rob my 93 LC AC lines for the battery box relocation and swap AC linesI didn't know that A/C dryers work sideways! That's good info.
