Start it already![]()
1ton cherry. 2 people. Slopped driveway. Don't want to remove sway.
Don't want to damaged anything. It was already heavy enough and hard to get the engine into the motor and frame mount. Struggled for 1.5 hours. Mainly a ton of beer breaks
Then my other buddies showed up and we had 3 people to stab in the trans with 2 floor jacks. That was kind of sketchy. I need to find a good used tranny jack for the future.
Not sure if it's touching but I will check tomorrow to make sure there's a little bit of a gap. Might need to trim more if it's going to rattle. My Turbo is clocked as far as it will go. I placed the turbo on the J pipe and snugged the bolts down. Then I put all the hoses and applied pressure downward and tighten the turbine housing bolts. It won't clock further down at this point.Photo- chair quarterback:
Is the air intake hose to the turbo touching the air filter chamber? You want a 1/2” space or it will rattle in reverse/ low rpm.
I clocked my turbo another 1/2” towards the engine, gained a bit more space for the throttle cable.
manual hubs
Why are you installing manual hubs if you converted back to awd? Great work on everything!
