split case twin-stick kits!!!!! (2 Viewers)
back at the shop, had a great time in UT but now it's reality check and need to get things rolling again. plenty of kits in stock.
hth
georg @ valley hybrids
You still making these or am I too late?
absolutely! pm me if you'd like to get one. :cool:
My kits are designed specifically for the later split cases. AA makes the twin-stick kits for the earlier one-piece cases. I do sell them, pm me if you're interested. $189 plus shipping.
Hth
Georg
Well, I got the kit installed and am happy with the improvement. Here is a picture of the shifter boot.
My only issue is that the sound insulating properties of this shifter boot are not very good. I am looking for alternatives - I recently insulated the floor with CruiserCrap and now the only noise in the cab is from the shifter boot...
Any ideas?
Dan
P.S. The shop switched the knobs... I switched them back.
Clean install, looks great!
If you want mote noise reduction and insulation, then there's a couple of things you can do. I would start with a flat sheet of rubber either 1/8" or 1/4". Drill your four corner holes and then cut two slots for the shifters. Use that "boot" first. Then bolt the double boot down over the flat rubber boot. It'll help quite a bit. If you want/need even more, then put some soft foam padding between the two as well. Just make sure you don't limit the linkage or shift lever throw.
Hth
Georg
Hi I'm Benny from Indoesia
I interested the Kit for 5 transmission.
Do you ship Internationaly and accept pay pal?
If yes, I need your help to calculated shipping cost to Indonesia.
Thank you
Thank you
Just info.
My trans come with a 4wd solenoid and I want to change with manual shifter
hey benny.
thanks for the replies. are you installing a 5 speed h55f in the cruiser and converting the transfer case to manual shifting? do you have the parts for the transfer case?
international shipping is not a problem.
hth
Hi Georg
Unfortunately I don't have parts for the transfer case.
Can you explained with picture everything is needed to converted
If can, I need all parts for that.
Converting from vacuum shifter to manual shifter.
Thanks
that's a good start but you still need to drill and tap the case for the detent or there's nothing to keep the linkage in 2wd or 4wd.
hth
georg
hth
georg
Sorry, I'm new about this.
can you show me where I need to drill and tap the case.
i want to order a twin stick and the shifter knob with the symbol like this but in alluminium.
and this one
if you can help me i need the rubber too like this.
i believe you more expert than me, please chose the right system for my trans.
do you accept pay pal?
Thank you
Hi Georg
I need 1 set of twin stick, 1 of 5 speed billet shift knobs, 2 piece of transfer case shift knob.
And this boot, i don't know the name
and this also this boot
After you know the total price including shipping cost to indonesia, please pm me
thanks
benny
hey benny.
thanks for the reply and pics. i have everything you're looking for in stock, pm on the way. international shipping won't be a probelm.
hth
