atnolan94
I'm Your Huckleberry
Does this bumper have gas struts to hold the swings open? Never seen anything about it.
Can you measure how low the rear side wings go down? I'm curious how much rear clearance you give up when using this bumper vs. a slee/BIOR/4x4Labs/etc.
This bumper is definitely not designed with wheeling in mind... It looks like you are basically at factory numbers for clearance and approach angles.
I've seen some pictures of the "ladder" style bumper and it looks a little less bulky. If these guys locally (as-in the US) are all in the $2500 ballpark for a similarly equipped bumper I wonder where all the cost savings is. I know the labor is cheaper but must be saving in other areas too....I guess there have been finish complaints as OP noted.
I get that. I'm not super wheeler, I just like to explore and take my kids camping. If it keeps the departure angle the same as stock, I would be fine with it for the price.
The cost savings is coming out of RD, quality welds and fit up, finish, materials, and small details (like hinges, clamps, and hardware).
Sure, I can appreciate that. I think if you are using it more for camping/overland type stuff, you are still going to run into some issues with the soflo... not having swingouts that lock out will be problem...
The Slee has the lockouts and stops to keep the wings open and in place.
...... seems like an expensive jerry/ water can holder to me.......
They come from the factory with a bumper... I would argue that a factory bumper cover and a hitch are better than this bumper.Well that and a bumper.
I dont get the point of this bumper if someone is staying with 33in tires bc a 33 will fit in the stock location.
I dont see the value, it does not seem to improve departure angle...... seems like an expensive jerry/ water can holder to me.......
I mostly agree with you. The soflo does miss one of the biggest criteria - departure angle - in a big big way. But, at least, as it's dragging its large ass over stuff, it'll likely hold together - where the OE plastic bumper cover would tear off.
