- Thread starter
- #21
What's the bolt you're using on the rear of the battery box for, to relieve pressure on the fusible link? Is it a copper bolt or something? Is that of your own design? I like it.
Yes - After installing the military type battery terminals (for which wiring) the poor fuseable links were stretched to the max.
I installed a "stud" (bolt with brass flat washers and brass star lock washers and nylock nut) and use a heavy gauge wire to extend the B+ to the back of the battery box. Could also be used for adding other accessories (lights etc...) Really, it is just a cheap B+ bus bar.
The fuseable link eyelet is directly contacting the heavy gauge battery cable eyelet -the bolt, nut, and brass washers hold it all tight through a hole drilled into the battery box.
It was inspired by this kit (but mine is not as complete). I need the LCP kit ASAP!
Feed up with your crappy 80 series battery mount? LCP has a fix
Battery Bracket Upgrade - Land Cruiser Products - LCP
