Slow Mo(tion), No Mo(ney) Build
Forgot - and the bushings were all shot. It knocked and thumped over bumps. If I don't like the handling, I'll re-install it with new bushings.
Oh gotcha. Mine had alot of lean with the front roved but not too bad with the rear removed.
Now that I added sliders and more weight the lean is returning so I'll be getting something back on there
I did the same thing when installing my Slinkys. Without the adjustable panhard in there, it wouldn't line back up. So, I ordered the adjustable panhard and just rant it without the front sway. After running it for a while, I realized that, even without the sway bar in there, the rear was swaying more than the front. 15,000 miles later, I haven't put it back in. Really, the best thing I did for handling was install the Delta rear panhard lift bracket. I'll might throw the front sway bar on when I get aftermarket radius arms that allow for more flex. But, for now, I'm not.
Great thread and clean rig, by the way. I like seeing clean green cruisers!
Old style👍, Rust 👎
Originally from MN, miss the beer but not the rust!
Hit 225k this morning.
A/C isn't working. My brothers shop and a yearly "special" in June where they diagnose the A/C issue for free - no requirement for repair. His tech evac / recharges and test for leaks to diag the system. If I decline the repair, they evac the refridgerant and I am good to go at no cost.
Bringing it in on Friday - hope an evac and recharge fixes it. Coupon below!
Interesting. After installing my 30mm front spring spacers, I was questioning the length of the shocks.
So I sent an email to Slee in Colorado:
Hello,
1997 Toyota Land Cruiser (series 80) with the medium OME lift installed.
I have these OME components installed:
Front Coil Springs (1 pair x 2851)
Rear Coil Springs (1 pair x 2860)
Front Nitrocharger Sport Shock (2 x 60018)
Rear Nitrocharger Sport Shock (2 x 60020)
Steering Damper (1 x OMESD24)
Front sway bar removed
Recently added 30MM front spring spacer to balance ride height.
Is the 60018 front shock length OK, or should I / can I move to a longer front shock now?
If so, which nitrocharger shock should I purchase with the longer length?
Thanks!
Response from Slee:
RJ, depending on the weight on your truck it would vary the front ride height. However the shock should still be ok. Any longer shock might cause the spring to unseat.
Best Regards,
Christo Slee
Nice!
Got my A/C fixed yesterday. Total cost....$99.66 - nice.
I have totally removed my heater control valve.
It is HOT and HUMID here this weekend and I just got my A/C working yesterday.
The A/C blows 100% cold air. I have the HVAC put in recirc mode. I cannot tell that the heater control valve is GONE.
So, I'm confident that folks from the northland can totally remove the heater control valve (eliminating all of its problems) and run it without and issues.
No complaints. I needed to lube them to install in upper spring seats, thats it. Great price too!
Why do you have to lubricate them? Is it too tight, can't get enough droop from the front axle?
Below is a picture of what I do when I am working on suspension, use the shops' forklift (yes there are 12-ton jack stands). When I put in my 850J I was swapping shocks too so I used a floor jack to keep the axle from dropping to the ground and ripping the brake line.
I lubricated the O.D of the 30mm spacers with Remoil (gun oil) and the I.D. of the land cruiser upper spring seat. The 30mm spacers are a tight fit and needed rubber mallet tapping to get them to seat fully upward. The lube just helped that out, then evaporated.
I needed to unbolt my brake lines to allow enough droop to install the 30mm spacers. Sway bar was also disconnected as well as both brake lines. ABS wires were loose to allow the droop.
So fun!
So fun!
Should've loosened up or taken off the lower shock nut.
I needed to tow the 18.5' boat for an extended distance. All this talk about coolant temp and the useless factory temp gauge got me thinking. Spending $100 or 3 hrs labor to simply see my actual temp didnt seem necessary.
I found this on amazon for $35
Amazon product ASIN B07P37WY1R
So far I have 100 miles on it, love it. While pulling the boat, coolant temp never got above 196F. 65mph and hills, lots of 3rd gear.
Pros:
-easy set up and configure the screen - almost plug in and go.
-read and clear engine codes
-Has GPS for speed (no map or anything)
-adjustable speed calibration for the MPH shown. with 35" tires, this will be awesome!
-the screen looks very high qyality, Sharp, clear and easy to read. Not too bright for night driving
-Easy double stick tape install
-small!
-low cost
-one button to change setting etc...
Cons:
-Needed to relocate OBDII connector to under the dash.
-Beeps when firing up each stat sequence.
-Only works when engine is running (I think). With key on engine off, it disconnects quickly. I might be able to change this....
After I get a few more miles on it, I will do a full review.
Things in the box:
Relocate OBDII connector. Endless possibilities here, this is where I put it using an existing screw:
Looks good and shows actual coolant temp! I mounted it to steering column. Might move it, but works good for now.
The lake and boat and Dad:
