Builds SLOW 71 (3 Viewers)
Put the pedal aside, until I can try out what I have. Jumped to the front bumper, as time is running and my Wife is headed to Moab in May with or without me and the cruiser. Stock bumper, but wasn't from a winch model. Want to check with you guys with pto winches and see what the mounting looks like. I welded all the mounting holes and am starting over, only two holes lined up. She will get powder coated. The plan is to bend my own grille guard if I have time.
3rd and 4th picture here have good display of the mounting holes for bumper I used with PTO winch: POTM - March, 2014 - Javelina By Pablo Cruise
PS: bumper gets sandwiched between extensions and front mount plate for winch:
img_1212-jpg.903371
Thanks Pablo,
Pictures helped. I figured the bumpers might be the same. My bolts for the two rollers are too long and will need to be trimmed. I don't have all those holes in the front like yours. Wonder what all that was.
Still playing around with the bumper and making some recovery points. Here's what I came up with. 3/4" material was on the metal rack, so it was picked. When everything is made, I'll weld them to the bumper. Am I missing anything or any ideas on why not to do this. I'm also going to reinforce the back of the bumper, so it doesn't kink so easy.
Thanks Guys,
Will it be removable after you weld everything together? If for some unforeseen reason you need to remove the bumper for a repair a welded to the frame bumper will often times transfer damage to the frame making an easy repair a nightmare.
Good deal!!
My pig is slowly turning me into the undisputed king of unforeseeable repairs, so much so that I’m now considering using Velcro instead of welding or bolts..
Damn, that's funny, but it's got me thinking. I haven't been off the farm yet. I might take a run for the title.
The stock bumper isn't all that stout. I'd be afraid the first tow job would deform the bumper. I'd try to tie into the frame so there isn't any force on the bumper itself.
I'd probably consider running through the bumper to connect to the frame rails.
NikP,
Take a look at the pictures, I have a 3/4 x 3 inch plate going through the bumper and bolting to the frame with four 1/2" grade 8 bolts. All I want to do is weld the plate to the bumper so it doesn't flex, move, etc. around. All the strength will come from the frame attachment ( I hope ).
Edit... Those plates are @ 8 1/2 inches long.
I always thought it was common practice to weld the mounts to the bumper, along with bolting to frame. Unbolting the bumper and recovery plates and take off as one unit.
I am uncommon and don’t like the idea of seen recovery points to begin with so take my opinion with a grain of salt, if you drive anything like I do then at some point you will be working on the long sides of that front bumper to get them back into position, you have 12 plus unsupported inches of thin sheet steel hanging out in the breeze just waiting to bump something and bend back. If you’re able to remove the bumper skin and lay it flat your chances of straightening go up, if you need to replace then retrofitting a skin alone would be easier than fabbing all the recovery points again.
Either way hurry up and finish the pig so we can go on a camping trip before I wear mine out..
What I want to do is reinforce the bumper with 1/4 plate welded in behind and then another horizontal piece welded at a right angle, midway, but you're right I smack something she's going to fold up.
I'm trying to get done, first trip is the Cruise Moab @ the first week in May.
I will always sacrifice a bumper skin to not bend a frame, this is why the bumper you see on my pig is 14 gauge steel and is easily removable with 4 each 3/8” bolts, I’m not a huge fan of over built bumpers attached to frames with thick plates, straightening frames sucks and if those long wings on the ends of your bumper don’t bend your frame will.
No match for a shopping cart! I'm not expecting to be ramming into trees with it. If I hit something so hard as to bend up my plated frame, then I'll have more than a frame to worry about.
