Slippery slope 60 with LM7 (14 Viewers)
“One question that I have that might already be answered here on the thread is that if I want to go to an 80 series steering box and I have an 84 what is the typical protocol? I assuming drilling and sleeving the frame, but is there a thread on this somewhere?”
I’ve asked the same question before .. there no thread that I’m aware of. But yes I’m told it doable by drilling and sleeving holes. Maybe add a plate on the inside?
If you attempt.. please post what you encounter and come up with!
I purchased a fj40 to fj80 kit from @cruisermatt that worked perfectly. If you look thru the pics you can see we cut out the whole section of the frame and welded the plates and sleeves in the. Worked great
Question is it normal for a fj60 to have this hole on the b pillar?
I am working on the exhaust manifold situation now. The stock LM7 manifolds do not play well with the frame and well sorted motor mounts. Since this car is CARB compliant I need to find some OE manifolds or some CARB/EO approved Manifolds. In the last week I became an expert on Stock GM Manifolds for all LS motors..LOL
LM7 truck manifolds don't play nice at all Driver side dumps right on top of the frame and pass side bangs into all the rear heater hose lines and brake lines. See pics below
05-06 GTO manifolds work of but not great they kind of turn into the frame where they dump and also bang into the OE motor mounts(can be fixed with grinding)
See pics below
C5 Vette manifolds seem to be perfect (vette gets em wet!)
I am confident that I have the right manifolds to make this all work. I am torn on using the OE engine mounts just for the fact that they live really close to the manifolds and I had to give them some love with a grinder so all could fit. I might just by some poly bushing ones from summit to see if I like the packaging better, but not sure...
Hopefully this weekend I can get tranny(Tremec tr4050), AA bellhousing and transfer case(hf2a) all mated to engine then slot it into truck and start working on crossmember.
Not much progress over here other than spending money on parts for down the road.
Cleaned up the engine a bit and bought all new sensors. It's a jasper rebuild and they paint the living sh!t out of everything with not much regard for mating surfaces.
Got pilot bearing and adaptor together then installed on crank. Need to now get flywheel on so I can do a run out test on bell housing(in order to get a warranty from tremec if ever needed, they need photo proof of this.
Also had to order some replacement bolts that axis wrongly provided in their adaptor kit for the transfer case. The thread pitch they provided was 12x1.75 and the transfer case threads are 12x1.25.
Also bought a beautiful set of fj62 doors, I want electric windows and locks. I will have to do the mods to make them work better.
Also was able to take the kiddos camping in Santa Cruz. Was cold as balls in the mornings, Cali cold that is 36 degrees. Lol
Either way hoping thru the holidays I can crush and get this project moving forward.
