I was up at RT Customs the other day watching the Jedi master finish up my Saginaw install and we decided to try out the new plasma cutter and MIG welder on my front shackle reversal/spring flip. We're using Trail Gear's spring and shackle hangers welded to the frame front and rear for the front spring only. Rear axle stays stock. As the front hangers have moved forward about 2" from the stock location, obviously so does my front axle, thus requiring the front shocks and shock towers to move as well. Front driveshaft will need lengthening I realize.
I have seen TG's universal tube hoops, Ford's towers, and stock mounts moved/welded.
What is the cleanest/strongest solution and what road handling issues have we created by moving the front axle forward 2"?
Just trying to troubleshoot this in my mind and see what others have done. Jedi Master @ RT Customs wants to use hoops.
Basic setup is 76 FJ40 w/350ci V8 mated to stock 4spd, OME suspension and 2.5" HFS springs on 37" Krawlers.
THANKS!
THANKS!
