Yep! I think your temps are too high unless you’re going up a steep grade or towing heavy accelerating hard.That's on a Scan Gauge?
That would be worth my time to try. Thanks!![]()
Radiator fins need cleaning! Alert Alert Alert
I've a 06LC w/192K I just bought. In reading history I found PO complained of engine temp raising when both front and rear AC on. Toyota Dealership diagnosed with clogged radiator fins. Recommended new OEM radiator, $600 for the US spec Radaitor plus coolant and labor. They should have added...forum.ih8mud.com
It makes a surprising difference!That would be worth my time to try. Thanks!![]()
At cold start, can not stop fan blades (clutch) for ~2 minutes.Did some further investigation:
Tried the rolled-up-magaizne-in-fan test, and it did not seem to faze it. This was done at operating temp. So I think fan clutch/clutch fluid is still good.
Most times it was not brupped properly, last time coolant drain/flushed. But be sure to hunt for leak.Checked coolant level, once cool, and found the overflow reservoir totally empty and the radiator about 1/2 gallon low. Topped off both.
So then question became: where did the coolant go??
Oil is check 15 minutes after hot (op temp) engine shut down on level ground. If set to high mark, when OF&L service done last. Will still be at high mark 5K miles later.Checked oil level (with fingers crossed) and it was at about the 1/2 point of the hashmarks. Going on 6k for this oil change, so about time to change. Would have expected watery and high oil level if leaking into oil.
A/C condenser should drain clear. If red from coolant, it would not be oily.Consulted with my more mechanically inclined BIL and told him there was no leaks under the bottom...only the A/C condenser drainage. But now that I'm looking at it, there's a lot of condensation drainage under it and it looks kinda red and oily...
So we think we found the culprit: heater core. Specifically heater core leaking into the HVAC housing under the dash and draining out the drain tube.
Good idea.We are going to pressure test to confirm and also more visual checks to ensure that fluid is indeed coming from the drain tube and not *near* the drain.
If need for sure. Not being able to stop fluid clutch (fan blades) ~2 minutes after cold start or as engine warms up to ~187F. Is a bad fluid clutch. These will usually not spin or very hard to spin even when engine off and cold, warm or hot.If confirmed, I'll round up a new heater core and probably a radiator while I'm at it.
Planning to install the new fan clutch that's on the way, since mine is OE and has 337k on it.
Heater cores very rarely fail in 100 series. Unless improperly maintain coolant system. i.e. using other than distilled water (DW) (98-03 Toy LL red 100%, mix with red/DW 50/50) in coolant system. No water should be add to 04-07 (Toy SSL pink pre mix). Failure to flush system and then park vehicle for extended period of years.If confirmed, until the new parts get here, I think I'll bypass the core at the firewall to avoid continued coolant loss.
Highway and stop-go traffic this morning just had me no higher than 193 this morning. 55 ambient. Amazing what the proper amount of coolant will do!![]()
