April 1971 Freeborn Red FJ40 w/1975 2F
Purchased in 5/05 from California
NO rust issues
Broke the 1st day I drove it................ dominioing from one repair to another
I worked on the truck for 10 months in my spare time. I have gone through everything now, creating a dd
Primary use:
DD/ business marketing tool, tinker toy
Secondary Use:
Touring Fla, camping, fire roads, and novice 4x4 events.
Driveway Mods Completed:
Rustoleum DIY oil based paint
Vintage 15x10 Vector wheels
33 x 12.5 x 15 Firestone Destanation AT
JTO Disc front brake conversion
1.5” wheel adapters (4)
2” wheel adapter (1)
LCR4WD Disc rear conversion (Poser)
Speed Bleeders (4)
4 Runner booster w/external vac check valve
80 series master
hard lines
soft lines (6)
Old Man Emu 13 front leaf springs
Old Man Emu 14 rear leaf springs
Old Man Emu bushings
Black Diamond shocks (4)
Greasable Spring Pins
Greasable Shakle Bolts
2” Shakles
Extended U bolts
MARK's OFFROAD HD U bolt skid plates (65SWB45)
4* caster shims
oem tie rods
oem relay rod
Center arm rebuilt
tres (5)
Black Diamond Stabilizer
Knuckle rebuild
New bearings (8)
rebuilt warn hubs
Rebuilt asian carb (fj40jim)
oem pcv
oem air filter
Edelbrock Sor 2 piece header
Tpi4x4 metal manifold gasket
Sor mid pipe
oem muffler
Sor tailpipe
1200* high temp silver rattle can paint
74 4 speed tranny
2f bell housing
72 3 speed transfer rebuilt
vac to manual transfer controls
Parking brake rebuild
74 drive shafts
oem drive shaft hardware
74 3rd Flanges and oem seals
asco clutch
asco pressure plate
oem Throw out
oem Pilot bearing
oem Clutch fork
oem clutch fork boot
oem fork pins
oem clutch ball
clutch master
clutch slave
clutch hard lines
Resurfaced flywheel
oem flywheel bolts
oem motor mounts
Flowed radiator
oem hoses
oem radiator cap
Oem tank repaired
fuel lines
Fuel petcock
Sylvania Silverstar headlights
Oem b/u, signals, side markers
Interstate Battery
Wix fuel filter
Wix oil filter
Shell Rotella 15w 40
Gates green stripe belt
Oem tail light brackets
71 oem steering wheel
Adavance / Discount auto round taillights
Oem rear step
Oem rear bumperettes
Confer rear hitch
JTO front Bumper
oem tow hooks
oem bumper supports
dash cap cover
oem license plate holder w light
Features I like about my 1971 and other earlier model year fj40s:
Chrome hood strip
"sharp" apron land cruiser badges
Ignition key on dash
Round rear tail lights
Smaller front turn signals
apron lights
Thicker steel throughout body
Large gas tank
17” “school bus” steering wheel
Drop down tailgate
Handles on hard doors
Vent windows on front doors
Spare tire on passenger side
Wipers on top of windsheild
Dad (tools)
Jill (wife)
Ih8mUD.COM - ridgerunner
Florence (dog)
Poser
FJ40Jim
Cruiser Guy
Gatorland Toyota Parts counter guys
Jimmy
Nate
Richard
Ot Davis Monuments / Sand blasting
Gunner
Cliff Hiebsch and sons
Brian
Bumber2Bumper 13th Randy & Tim
Roland Stuart Cycles/ Machine shop of Gainesville
fsm
before pics
NO rust issues
Primary use:
Secondary Use:
Speed Bleeders (4)
80 series master
hard lines
soft lines (6)
2” Shakles
Extended U bolts
4* caster shims
oem tie rods
oem relay rod
Center arm rebuilt
tres (5)
Knuckle rebuild
New bearings (8)
rebuilt warn hubs
oem pcv
oem air filter
Sor mid pipe
oem muffler
Sor tailpipe
74 4 speed tranny
2f bell housing
74 drive shafts
asco clutch
asco pressure plate
oem Throw out
oem Pilot bearing
oem Clutch fork
oem fork pins
oem clutch ball
clutch master
clutch slave
clutch hard lines
Resurfaced flywheel
oem flywheel bolts
oem motor mounts
Flowed radiator
oem hoses
oem radiator cap
Oem tank repaired
fuel lines
Fuel petcock
Interstate Battery
Wix fuel filter
Wix oil filter
Oem rear step
Confer rear hitch
JTO front Bumper
oem tow hooks
oem bumper supports
dash cap cover
Chrome hood strip
apron lights
Large gas tank
Drop down tailgate
Dad (tools)
Jill (wife)
Florence (dog)
Poser
FJ40Jim
Cruiser Guy
Jimmy
Nate
Richard
Gunner
Brian
fsm
before pics
