Builds Removing SBC conversion, going back to Toyota. 1972 Frame Off (1 Viewer)
I have been looking thru your thread .... Nice!
I will need to finish up during lunch tomorrow lol
Love the parking brake pics... I will definitely need to reference these pics when I dig into mine... Mine will NOT be as clean as yours :) it's been some time since I had mine apart and I recall I was missing something last time I was in there. I don't think it is the reason for nonfunctional now... Think it is the shoe separating as last time it happened
Where did you get your speedi? Or is it a Timken sleeve?
Great job
Great job
Thanks Johnny. Speedi sleeve was sourced from SOR. I didnt want to take a chance sourcing it locally. I think Amazon carries ot as well. The parking brake was my most challenging job yet as I was working only from the FSM and SOR schematic .
Why not use the entire 60 axle? You get a wider wheel base (3") which means greater stability. Not too much work to out board the springs a bit.
Dyno
Dyno
Our goal with this rig is for the modifications to appear stock. Originally I was going to use a 76 axle for donor brakes but decided on the 60 brakes after the frame was finished(ecoat dip and industrial polyurethane) Also by using the early axle housing, I don't have to change any of my brake line locations.
Starting to think about body and paint. My original passenger fender is twisted beyond my abilities. I was able to find this OEM new fender new from a local cruiserhead for less than what labor to fix the original would be.
J,
I had to break the coarse spline off the 68 axles to make them work with the 60 fine spline. Pretty sure the DS (LH) was good, but the PS (RH) had to use the 60 birf with the 40 axle. I may have this backwards, it been awhile.
J
Thanks Jason. I'm having issues finding a concrete answer. This front axle is driving me nuts.
The FJ40/50/60 short side axle shaft is the same.
Use the 60 birfs w/ short side 60 shaft and long side 40 shaft.
edit: Why is that knuckle full of red wheel bearing grease?
Thanks Jim. I am not sure on the wheel bearing grease in the knuckle. It looks like PO did a rebuild prior to parting out. I will be reassembling with the correct grease.
There it is. It had been too long for me to remember which swapped out.
Jim, Interested in doing another carb for me?
Jason
Jason
Jim has been a huge resource on my build. I went out to test fit the long side axle and came in from the garage to his post confirming what I found out.
Today I had a few spare minutes and torqued the ubolts to 95 ft lbs. Weight is on the suspension and i am happy with the shackle angle. Its only going to get heavier from here.
Next steps are to switch the 60 birf onto long axle, grind my knuckle balls and the hopefully onto reassembly.
I am thinking about retitling to slowest build ever.
