- Joined
- Dec 7, 2013
- Threads
- 22
- Messages
- 84
- Thread starter
- #21
The 02 sensor is right under the drivers seat on the exhaust. The Coolant temp sensor was working fine, we compared the readings to a thermal imagine gun. I would like to believe the 02 sensor got nuked cause the sniper could not control the fuel prime. With the prime setting on it would just continuously piss fuel out... so we turned that off.Are all of the sniper sensors reading reasonable values? My sniper arrived with a dead coolant temp sensor, it was reading a low error. New sensor was 11 bucks. The black plugs suggest that it was running really rich either from a vac leak or bad sensor. Where is your 02 sensor located? Those sensors can also get nuked pretty easily if you are doing multiple rounds of fuel pump priming and short runs of the engine without getting everything up to temp.
Also i read that turning the closed loop on (or off, i dont recall) bypasses the 02 sensor and that wouldnt work either.
The engine would idle up until it got to temp, then the sniper would just loose its mind and kill the car with poor idling and backfiring
