I have read every thread I can find regarding removal of the air rail. Blasted each rail union with PB for several days. The top bolt on the union for the first 5 easily turn. Getting a 17mm wrench on the back firewall union has been the challenge. Really want to get this off without damaging the tubing which I hear is common. Want to keep the rail in good working order should I have to reinstall at some point in the future.
Here are the solutions I have read:
- Shear off the tube with a chisel and remove both bolts with socket. Don't want to trash the rail if possible.
- Remove temporarily the rear engine suspension hook by extracting block bolts. First open radiator cap to relieve any built up pressure.
- Remove anti-freeze bearing hoses back there to get better wrench access. Prefer not to drain fluid and burp if possible.
