- Thread starter
- #661
Started with the next attempt with the floor.
Fresh steel.
Angle correct.
Fresh steel.
Angle correct.
Ordered some steel today for a welding table and a jig.
The jig is going to have the mounting points for the body to make alignment possible.
Elevated points will allign in height.
The jig will also guide the Rebuilding of the frame after disassembly and blasting.
Any of you with experience in using a jig?
Thank you.Jaw dropping stuff. Thanks for sharing the tips you use. I am sure many will benefit from this. Awesome!!!
This is going to be different.Only woodworking (dovetails, etc.) and I doubt that would help you.
Thanks.I’m impressed that you’re cutting and patching all that rust, most folks are leaning towards finding new tubs or going aluminum nowadays.
I like your style, I did the same thing.
