No , I think it will grab LESS teeth because it is further from the adjuster. But maybe the trick is for it to put less tension on the adjuster teeth/dial and being further may help with that. I'm really not sure how this is engineered. I mean I don't know how the set up determines EDIT: when the lever will stop adjusting the adjuster out. I mean if the brake shoes are tight to the drum wont' the lever still move some? does lack of pressure keep the lever from turning the adjuster or does the lever travel less some how and not grab any teeth? But it stands to reason that if you shimmed it out and it helped some, that you would try and shim it out more to see if that fixes the issue.laterally, will help it grab more teeth.
