Rain Gutter seam and drip rail reseal (1 Viewer)
I see a can of pre-painting prep from Eastwood in one of your pics. Is that just isopropyl alcohol?
Also how well did your paint adhere to the sealant?
I believe it is just that or acetone in aerosol form. Wax remover is another term for it. It's convenient stuff.
The paint has adhered extremely well so far. Both sealants are designed to be painted over.
This is a great write-up. Thanks for sharing this with us.
How was the Eastwood 2K Epoxy Primer to work with? Any issues?
Do you guys leave the chrome trim off the drip rails? This trim seems to cause more leaves and gunk being stuck in the drip rail.
No useful purpose. Only bling. It is OEM standard but keeping or removing depends on rig intentions.
Dump the chrome, seal up for the loong haul.
Cosmetics are for cosmeticians.
As blingy as the trim is, I've always replaced mine when one of them gets wrecked or torn off.
The gutter lip is metal with a sharp edge. It is very easy to wear off the paint on those edges, leaving bare steel. Bare steel = rust.
So as much as the chrome is kinda annoying, it certainly does protect the gutter edges from abrasion/ rust.
World class job of prep, install and photography. Having said that, since you're in a wet climate, I'd keep an eye on it as the years pass, especially if the truck is parked outside.
Great write up. This should be added to the faq page. Easier to find
many thanks to patrick for posting this info. i'm using the same products for my reseal and especially like that the evercoat sealer uses a standard gun vs. the special gun the 3m self leveling sealer requires.
one tip i can offer -- use a heat gun to soften the old sealer before removing. i used harbor freights $9 heat gun and had all the old sealer out in 1.5 hrs. came out very easy.
All I know is get something with a long enough “working time” so you have enough time to apply it and then go back and smooth it out. I used a 3M controlled flow with like a 2min work time and did it on a hot day... not pretty. But it’s sealed :hillbilly:
Great write-up. I am getting my 60 ready to go into the paint shop at the end of September and have added this to my list of prep.
I'm curious too. I'm hoping to get my 62 into a body shop to get some dents and minor rust fixes done (found some spot under the gutter, wuh-oh) and I figure I'll just have them reseal the gutter while they're doing all that so it can be one and done and I can paint the truck.
  • Back
