It should be pretty simular to the stock radius arm, since y-links are just a different style of radius arms. Sorta like EB's were just a different style radius arm.
There is a pretty big difference. The separation between the bush's on the lower end of the radius arm controls the diff wrap and braking forces. In stock they are close enough to level between these points. If the same separation is turned vertically. Totally different road handling and much less binding. Road handling sucks. That's why most people find the sweet spot between 45 degrees and level. For best road handling and less binding. Mine is a some what same approach but from a new aspect. They aren't just flipped arms.
If so can you share your plans?
