What are the details on the rest of the front suspension components?
that's some serious flex you have there mate ..
Very impressive dude.
Wanna do mine ? ill bring alot of drinks ?
That is pretty well done big boy, better then some 'professional' 3/5 links going around
You'll find that raising the panhard and draglink is a big factor in the improved driveability. Probably more then the radius arm flip itself.
You'll have to rework your shocks and alot of components though mate. Its maxing out 14" on the front. Im going to have to start doing them I think. Lots of offers. Might make a drive in, drive out price for the complete tuned set up. Bump stops, coils, shocks, panhards, reworked brake lines. The lot.
Suspension shops dont have a clue. They just fit the stuff. Then I have to fix it and make it drive lol.
Its just a passion mate. Im extremely thorough with my R&D and personally test every aspect, and over a duration of time to see how it holds up. Made a few big advances in alot of area's already.
Thanks for the comments.
It actually surprises me that no suspension companies offer uprated sway bars as part of their kits. Instead relying on firm compression valving on the shocks to stop body roll. Which of course doesn't work anywhere except a perfectly flat race track.
That is some nice work your doing there. It is more like suspension engineering than suspension building though, which, in defense of suspension shops, isnt really what most of them do, know or often care about.
Anyway, there was a post about a month or so ago about using a bar between the two front bushings, with a pin to the center of the axle. This way there is very little binding of the bushings with articulation, as the bar splits the difference of the rotation of the axle in the situation where only one side of the axle drops. Just to be clear, the rear bushings would still attach to the axle, the front bushings would attach to a bar with bolts out the ends. The center of the bar has a hole through it, which is placed over a large bolt/pin with a bronze bushing, the center pin is welded to the axle.
I mention this as it may be of value to you in you future design, it makes alot of sense to me, if I had the time and not so many projects on my plate already I would consider the radius flip with the bar.![]()
TheBigBoy said:Ha ha, alright then. You wouldnt be the first to offer. But you wouldnt like the bill.![]()
Walking Eagle said:MAF used to offer oversized swaybars. It's not just stiff shocks, the tendency is to put overly stiff springs on too.
Why not offer a pre-flipped housing?
