Hi All,
I know someone is going to say search the forums, and I have.
I am struggling with a 5 speed solution to my R2.8 to FJ40 build.
I can go with something non-toyota, then I need an axle swap or at least an axle centering done. Then I need an adapter and a tcase that works.
I was leaning towards the H55F option but they are pretty expensive to get for me in Canada.
There are quite a few B diesel H55s available to me, even in BC, but I don't know if it will work.
The adapter I would use for the H55 is from Quckdraw and I asked them if they knew if a diesel version (B series) would work with their adapter and they aren't sure, because they just used a Gas one to develop it.
The one they used is a 10 spline and this is a photo of it:
Is the issue with the B H55 to the gas engines the bellhousing or truly the input shaft. I found somone's horror story of changing the input shaft to work with a gas engine, not sure if that is everyone's experience.
If I can get a good core in BC (with tcase) I would want to go through it anyway (whether myself or shop) seems like changing an input shaft can't be all that awful! If it's even necessary if I am going with an R2.8 and adapter.
Hello, transmission gurus, are you there?
