Hi guys,
It's been awhile since I've been around since a new Sprinter van has been the obsession of my automotive ADD over the last year.
But I'm back...and with a problem!
Background:
When I last left off with my LX, I had performed a brake job (in several stages over a couple of months). The car mostly sat in the driveway during this period, and after. I did the front brakes first as part of a knuckle job. Car stopped beautifully. I later went to do the rear bearings, calipers, rotors, etc. At that time, I also replaced all the soft brake lines on the vehicle.
After that, the car would pull to the right when braking, sometimes very heavily, but always to the right. Having just done the rear brakes, and having used some "Centric" brand calipers, I figured that maybe there was an issue with the calipers.
Then the truck sat for about 6 months...
Where Things Sit Now:
This weekend, I replaced both rear calipers with new one but the problem persists. I then noticed after a test drive that the FRONT RIGHT wheel is significantly hotter than the left front wheel. So I figured that maybe the left front caliper has a sticky piston or something, causing a reduced braking pressure. But upon inspection, all 4 pistons seems to operate smoothly. I did test to see if all 4 pistons move when the brake pedal is applied. They did, but not evenly, and my wife had to pump the brake pedal a couple of times to get the pistons to pop back out. For what it's worth, the front right caliper acts the same. I don't have the automotive experience to know if that is normal or if they should all pop out almost instantly and evenly.
Ideas?
Knowing what I've done, and the symptoms I've described, I'd love to get some ideas on things to check out. Kind of at a loss for what to do now.
Thanks!
Background:
Ideas?
Thanks!
