Projecting, tinkering, fiddle-farting around: whatcha building? (12 Viewers)
Got around to making some trellises for the wife. Rough sawn cedar I ran through the thickness planer to 3/4". Then ripped 3/4" strips from the boards. Narrow crown staples and some Titebond III to hold them together:
I’d like some. I’ll send you my address. :D
Well it’s a little higher than I wanted, but I can lower it later. It’s no where near done either, but it’s off the ground at least. Progress!
for to make a mount to fix this "recovery gear" case to the rhino rack platform... The cases stack and interlock with a swiveling side handle...
soooo...
now to fill it with appropriately useful things. and raise my garage door header! :bounce2:
soooo...
View attachment 2289880View attachment 2289881View attachment 2289884
Nice creativity!
A possible concern- if you have recovery gear in it, are those plastic tabs you have the round bars hooked to going to be enough to secure it on the roof, especially with a hard stop? Or are you planning to strap it down further?
Nice creativity!
So those are on each side. I could further secure with a strap but one of the things with this is it secures the box AND still allows me to open w/o unstrapping. I kinda tugged on it while standing on the slider and its pretty solid, rocked the whole rig a bit..., so its good, esp for version 1. 😉
Sounds good. And makes sense to me. I'd hate to hear about a design issue leading to a roof-missle.
Good idea. What brand box is it?
Its a rigid from home depot.
Looking all over the farm for a 6" length of 6" pipe that was here when I bought the place 26 years ago...to use as a collar between 2 old propane tanks for my rocket cooker. Couldn't find it but found a stack of 16" plow disks in the granary.
Welding is fun. Grinding not so much.
4 coats of seasoning. Nuff of that.
I'm hungry. Now I just need to source some meat. Descada might be out of the question for the time being.
Nice!!!!!!
Oh, it must've migrated out here... 😆
That's going to be my vise stand
Okay, I’m done for today. The wood burning wasn’t turning out how I wanted so I stripped it. I had to redo the blueing do to newbie error. I went ahead and used the supplied steel shim vs a wood one since I had it. I don’t believe it’s coming apart, but I’ll keep an eye on it. Still need to make a leather sheath, to be done later. I’ll finish it all off with a oil wax and call it good for now. Now to clean up my mess. 🤘🏼 This is a NOS Russian axe from the 80’s. I had planned to do some wood burning on the handle, blue the blade and make a leather sheath.
Wheel barrow mod...
The stock fork binder kept catching on everything like a low skid plate. . . .
All-thread run through the conduit sleeve and bolted up the plate.
On the kitchen table??! 😳😳
Props for flip flops though!! 🤘🤘👍
That was just for wood burning and the flip flops are steel toe, so no worries.
Hot tub project part 2:
I had filled it to check for leaks after removing the factory heater, so had to drain it (not fun).
So I installed a new ball valve and drain hose, then with a socket on the side skin so I can hook up a garden hose.
Next I drilled two 2.5" holes in the side for the wood heater and fitted the ports for that. No photos yet.
I then re-skinned the tub, and made several sections easily removable.
As it sits now, it's a cold water tub. Jets and pump work great. Just need a filter and water treatment.
Next up will be sorting out the filter, installing an ozonator, making a ground level deck, making an access panel for the wood stove plumbing, and moving it to the deck, which will be a few months out.
So I installed a new ball valve and drain hose, then with a socket on the side skin so I can hook up a garden hose. View attachment 2295787
I then re-skinned the tub, and made several sections easily removable. View attachment 2295788
Awesome support staff too!!!
