Builds Project Lockjaw-1973 Fj40 on Tons (1 Viewer)
Are you going to run a rear mount on the output of your atlas? I did similar cross member mount in the middle like yours but I was worried and put another on the rear output shaft on another cross member? I also used it to mount my skid plate to so it worked out well. Just wondering? Your build is looking awesome and the mini turned out really good bet your boy is happy...
Yes I will be running an Atlas support of the front side of my four link crossmember. Will be cutting it out of half inch plate and making it two pieces.
354 days until GSMTR 2022…. :beer:
Coming along great! Keep up the great work!!!
nik
Thanks Nik....and thanks for the reminder on the next GSMTR. Hope to have it there next year
Getting some more floor sections mocked into place
Just need to cut out the section for the gas tank area.
Cut out the gas tank relief area from a donor. Made a new bottom section out of 18ga to replace the rusted out section
New metal welded in. Just have one little area to cut out where the rust went a little higher than the patch panel.
Back on the rear four link today. Got the lowers replaced with some 2" DOM 1/4" wall tubing.
Almost finished up with the passenger side floor pan section.
Coming along nicely sir. So are you keeping the tank under seat?
As of now, Yes. Can't really find a better place for it. On a side note, was just on STLCA club page and really like how active it is. Can't belive the rant that Larry went on about next years GSMTR. More to come on the Lockjaw build.
Work has been slow on the project. I did however get some work done last night with the help of a friend from RockYour4x4, Jason Cooper. Got the front lower links mocked up.
Got a little work started on Lockjaw. The two halves of the passenger side floor are welded together. Mocked it all up even with the 12" floor extension
Awesome
Looks good!!
Anyone that has done an LS swap, what headers are you guys using? The ones that are on my 5.3 kick the exhaust flange right on the frame.
I think m using trick flow huggers. They’re center dump style and allow creative routing in a tight frame. No word on longevity yet.
