Hi,
the power window switch panel on the driver side has stopped working on my 2001 Cruiser. And to make things worse, the driver window was down and I cannot close it.
None of the switches work, can't control any window, the central locking system or switch to disable window control. All other windows can be opened/closed from their respective switches.
I've removed and opened the master switch, nothing is visibly at fault. I've looked at the fuses inside the cabin and under the hood, all seem fine. I've removed the door panel, and inspected the wires - they seem fine to me.
I think this is a fault in the panel itself, since nothing can be controlled from it, and there is no sound when trying to control the driver side window.
1: has anyone else here run into this? (I've searched, but not found this particular issue)
2: is it safe to apply voltage from the battery to the window motor to close the window? Will I run into issues (when I've fixed/replaced the panel) with alignment or needing to reset the window ?
Thanks,
Jon Arnar
Thanks,
Jon Arnar
