Possible bolt in 140-145a alternator (1 Viewer)
Denso P/Ns by any chance?
rock auto showing all denso accessories back in stock, get em while they last just an fyi i had to send one alternator back because they shipped it like dog doo doo and the rear casing was cracked, refunded and swapped with a new one no problem though.
130 amp alternator (sequoia/tundra) More Information for DENSO 2101065 - https://www.rockauto.com/en/moreinfo.php?pk=11195357&cc=1432860&pt=2412&jsn=1199
150 amp alternator (sequoia/tundra) More Information for DENSO 2101066 - https://www.rockauto.com/en/moreinfo.php?pk=11195361&cc=1431001&pt=2412&jsn=1408
2.0kw starter More Information for DENSO 2800168 - https://www.rockauto.com/en/moreinfo.php?pk=1293013&cc=1276703&pt=4152&jsn=1301
a/c compressor More Information for DENSO 4711166 - https://www.rockauto.com/en/moreinfo.php?pk=2023250&cc=1276703&pt=6628&jsn=1330
Seems to be what Rock Auto shows as "OEM / Interchange Numbers: 19134494"
In one picture I took, I see this same number.
I searched "Denso 19134494" and found it for $103 at 2003-2009 Jaguar XKR Alternator - Pure Energy 13979 - - PartsGeek.com - https://www.partsgeek.com/8j741bq-jaguar-xkr-alternator.html At that price I will get one for my 1993 from Parts Geek.
All lights installed and still working great. I rerouted the B terminal wire to my fuse holder. I'll get a picture of that when I have a chance.
@Inukshuk that's way easier then what I did!
Fantastic work
Thanks! Only possible because I had your and other experiences to build on.
Anyone have the P/Ns for the NEW Denso alts? Or are they NLA?
It seems to be kind of elusive. The number I'm seeing is 13979 or 104210-5040. Also, as odds would have it I have a Jag 4.2 laying on the floor of my shop so I popped the alternator off and it's the same but of course it's a reman and doesn't have the Denso number on it. Seems it's the same alt for pretty much all Jag 4.2L. I have an XJ 4.2 I'll be pulling soon so maybe I'll get lucky and have a Denso number on that one. Here is an application list if anyone wants to keep an eye out while cruising the junkyard:
Jaguar(60 vehicles)
* Hover over the year range to see exact years
S-Type Base with engine V8 - 4.2L 4196cc 256ci GAS MFI - 4 valve DOHC
2003 ,
2004
2 vehicles
S-Type Base with engine V8 - 4.2L 4196cc 256ci GAS MFI vin B - 4 valve DOHC
2006 ,
2007 ,
2008
3 vehicles
S-Type R with engine V8 - 4.2L 4196cc 256ci GAS MFI Supercharged - 4 valve DOHC
2003 ,
2004 ,
2005
3 vehicles
S-Type R with engine V8 - 4.2L 4196cc 256ci GAS MFI Supercharged vin C - 4 valve DOHC
2006 ,
2007 ,
2008
3 vehicles
S-Type Sport with engine V8 - 4.2L 4196cc 256ci GAS MFI - 4 valve DOHC 2005
2005
1 vehicle
S-Type VDP Edition with engine V8 - 4.2L 4196cc 256ci GAS MFI vin B - 4 valve DOHC 2006
2006
1 vehicle
Super V8 Base with engine V8 - 4.2L 4196cc 256ci GAS MFI Supercharged - 4 valve DOHC
2005 ,
2006 ,
2007 ,
2008 ,
2009
5 vehicles
Super V8 Portfolio with engine V8 - 4.2L 4196cc 256ci GAS MFI Supercharged - 4 valve DOHC 2006
2006
1 vehicle
Vanden Plas Base with engine V8 - 4.2L 4196cc 256ci GAS MFI - 4 valve DOHC
2004 ,
2005
2 vehicles
Vanden Plas Base with engine V8 - 4.2L 4196cc 256ci GAS MFI vin B - 4 valve DOHC
2006 ,
2007 ,
2008 ,
2009
4 vehicles
XJ8 Base with engine V8 - 4.2L 4196cc 256ci GAS MFI - 4 valve DOHC
2004 ,
2005 ,
2006 ,
2007 ,
2008 ,
2009
6 vehicles
XJ8 L with engine V8 - 4.2L 4196cc 256ci GAS MFI - 4 valve DOHC
2005 ,
2006 ,
2007 ,
2008 ,
2009
5 vehicles
XJR Base with engine V8 - 4.2L 4196cc 256ci GAS MFI Supercharged - 4 valve DOHC
2004 ,
2005 ,
2006 ,
2007 ,
2008 ,
2009
6 vehicles
XK Base with engine V8 - 4.2L 4196cc 256ci GAS MFI vin B - 4 valve DOHC
2007 ,
2008 ,
2009
3 vehicles
XK8 Base with engine V8 - 4.2L 4196cc 256ci GAS MFI - 4 valve DOHC
2003 ,
2004 ,
2005 ,
2006
4 vehicles
XK8 Victory Edition with engine V8 - 4.2L 4196cc 256ci GAS MFI - 4 valve DOHC 2006
2006
1 vehicle
XKR Base with engine V8 - 4.2L 4196cc 256ci GAS MFI Supercharged - 4 valve DOHC
2005 ,
2006 ,
2007 ,
2008 ,
2009
5 vehicles
XKR Base with engine V8 - 4.2L 4196cc 256ci GAS MFI Supercharged vin B - 4 valve DOHC
2003 ,
2004
2 vehicles
XKR Portfolio with engine V8 - 4.2L 4196cc 256ci GAS MFI Supercharged - 4 valve DOHC
2008 ,
2009
2 vehicles
XKR Victory Edition with engine V8 - 4.2L 4196cc 256ci GAS MFI Supercharged - 4 valve DOHC 2006
2006
1 vehicle
Sorry to revive this, but it seems like the jag battery is still the best route considering the non-existent tundra/seqouia bracket.
To add something, Rock Auto has a Bosch reman battery for the 03 XKR (al9433x) that supposedly pushes 220a. I confirmed this by looking up the pn on Bosch's site. I just ordered one, I'll report back when i get it on and can amp clamp it.
@Tam4511 - Did you receive your AL9433X from Rock Auto? I signed up for notifications and ordered one when it came in stock, just got "it" today. The box is "correct" (labeled AL9433X), but it's an AL1290X (90A, different case), so it's going back... (never done a return to Rock Auto before, ah, good, turns out returns are free for a mis-boxed item). Make sure you check yours before the return period is over!
Good call, I just checked mine and it looks to be right.
Did you ever test if that AL9433X will fit?
Here's another option for those interested. Just installed into my 95, and with some slight mods to the tensioner it works great! 180A, all new (not reman) genuine DENSO product. I'm very pleased!
The Bosch 220a I previously mentioned is only $170
well the one from power bastards was direct bolt in same size as factory. Was a plus for me
