subscribe
I've seen your rig a bunch of times in pics here and there, saw the article in (iirc)4wdTO? Sick rig man, I'm jealous, but working towards a similar ending setup. I have a damm truckload of questions about your rig, but I'll stick to the topic! I plan on the 3/4 ton springs as I have a full-size spare hanging off the back, dual jerrycans, hi-lift, and a lot of weight just from my gear. Trail tools are heavy, and add the Mrs, daughter, and all their gear and we're well into the 7k/lb range, so I'm going to need the added height for all that jazz, and I'm not one to shy away from a taller rig, I just take the slightly less difficult lines and enjoy it all the same!3/4 ton chevy 63s with 14" smooth bodies and a 14 bolt. Dunno if the 14 bolt has enough of an offset diff to clear gas tank and driveline, but I think probably. I no longer have stock tcase or gas tank so I can't say.
Works good for me. Rides decent. Flexes well. Took a few tries to find the right pack with all the weight I have. I think a beefed up 1/2 ton 63 pack would be fine for most but the 3/4 tons are working better for me.
I think @maxamillion2345 has rear leaves?
I think the issue with leaves up front will be the steering link behind the axle? Maybe you've already taken care of that?
Maybe consider a 14-bolt or D60 out back in light of recent issues...
60f/14r is down the road a ways. Too many other things going on in life at the moment to do that. I also want to change up my trans/tcase before full widths, but eventually I will get there. I want to avoid "BOOM" as much as possible. As far as that goes, is $600 still the ballpark price for rear shafts? I thought I had seen some in the lower $400 range, but couldn't find any availability, maybe a discounted part? Maybe Poly Performance was the ones I saw for cheaper?
-Did you have to modify the spring packs or are the 3/4t a plug and play as far as height and weight carrying capabilities? As seen I'm going to run the creeper shackles to free up a bit if torsional resistance, built my own years ago and they worked really well, so I figure if I do end up with a stiffer, taller pack it can't do anything but help it twist.
-If you kept the axle location in the wheel well the same or relatively close, how far is the shackle mount from the rear of the frame? Close estimate works, I'm just trying to get a relative idea for a mount idea I have cooking.
-Is your rear axle full width? Maybe it's the 80's being the mid size that makes a full width look not as crazy wide!
Now THATS a thing of beauty!!!Just in front of body mounts
haven't been on in a while and just saw this. i have a 14bolt and basically stock drive shaft and it all clears the stock gas tank. it even cleared when i first did the swap and only had about 2.5in of lift.I have no idea. What I do know is I would rather put $600 into a 14bolt than $600 into an axle that isn't going to cut it.
Heck you can get a 14 bolt for $150 bucks if you shop a little. I think @wv_lx450 has a non-modified one outback... He might have a fuel cell though - can't remember.
Nice. Never seen this until now. How do the 40s stuff in the rear?Just in front of body mounts
