How about color sand with 800 grit till you see green then do thr easy off.. to take off afew layers of blackI have been a lurking member for a while (we have an 80 and 100 series), but I bought this '72 about a month ago. It had been sitting in my friends field for around 20 years. I've been asking about it for about 15 years. He finally got sick of me asking about it and sold it to me. We brought it home, cleaned out the years of dirt and garbage, put a new battery in it, and it started up. Amazing! It still needs the brakes and clutch overhauled and a lot more, but it I was surprised it started up.
I like the idea of getting back to the original green paint and keeping it there with whatever patina it may have. I have read on here that guys have used Aircraft stripper, Citrus stripper, Goof off Graffiti Remover, Safety Kleen paint stripper, and Easy-Off oven cleaner. I tried the Easy-off with a blue (non-scratch) scotch-brite pad on a section of the rear corner. It took me three applications of letting the Easy-off sit 5-10 minutes, then scrubbing with the blue pad a few minutes, then wiping with a towel and rinsing it to get to where the picture shows. I chose the Easy-off because it seemed the least drastic, but it did take a while.
Should I expect to take this much time to remove the black paint?
Is there a faster way to do it? I don't want to mess up the green paint.
Thanks for any help you can give.
I will try that.How about color sand with 800 grit till you see green then do thr easy off.. to take off afew layers of black
Everything I know about this stuff I learned in the patina tips thread, so take it for what it's worth, but I used Goof Off to take off some rattle can primer I had had under my diamond plate and it took it off pretty easily. Didn't seem to affect the original paint though I wiped it down as soon as I got it off. I would at least buy a can and play around with it if I were attempting what you are.I have been a lurking member for a while (we have an 80 and 100 series), but I bought this '72 about a month ago. It had been sitting in my friends field for around 20 years. I've been asking about it for about 15 years. He finally got sick of me asking about it and sold it to me. We brought it home, cleaned out the years of dirt and garbage, put a new battery in it, and it started up. Amazing! It still needs the brakes and clutch overhauled and a lot more, but it I was surprised it started up.
I have heard of this method of blasting, but don't know of anyone in my area doing it. I wonder if it is more expensive than other methods like steel shot or aluminum oxide? I usually get my parts done with steel shot since it comes the best IMO, but it tears through ALL layers of paint/bondo/undercoat almost immediately. You're not going to "preserve" any patina unless it's a bare blasted steel look you're after.This is a long shot but if you can find an outfit that has a dry ice blaster it might work real well.
It's like a sand blaster but uses dry ice pellets. The process was developed to strip paint from aircraft without damaging the aluminum skin. The other benefit is the only residue is paint dust.
I had a supplier do a demo in the factory. We were thinking of using the system to clean rubber molds. In the maintenance area there was a very large, very old steel workbench. It had several coats of oil based enamel paint on it. The demo rep hit it with the dry ice blaster and it cleanly removed one layer of paint at a time. It did not change the luster of the paint layer underneath.
This process is used not only for aircraft but cleaning the inside of bulk storage tanks....etc.
