Build Over the Hills, and Far Away
Okay, things have happened - more on that later - but for right now, I need opinions: I need to settle on a tubing diameter for the cargo rack supports.
I'm considering 1", 1.125" and 1.25" tubing at appropriate thicknesses...or 25, 28 and 32-ish mm for those of us with modern metrology. I'm basically going to be making a hoop at the windshield, a pair of uprights or a second hoop at the rear of the tub, and I might - repeat, might - tie those pieces together front-to-rear with a subframe to which the existing rack will bolt, because Additional Reasons; don't worry about how it'll all mount and connect...this is only a question of diameter. I used to run a Gobi on my Jeep, and its largest members were made from 1"/25mm tube...and it was plenty strong. That being said: thinking ahead, I have more uses for larger tubing diameters in other locations. 1"/25mm is fine for some things, and 1.125"/28mm would be appropriate for a few additional projects, but 1.25"/32mm would be very useful...so that's my leading contender. I don't really want to double up on bender dies right now, so, opinion:
Do I go with 1", 1.125" or 1.25" for the cargo rack subframe?
Saturday Morning Update: I may have answered my own question with the tubing. I found a paint roller handle that's exactly 1.25" in diameter, and that's honestly the smallest that I'd want to go...at least as far as aesthetics are concerned. I could likely go up to 1.5" and still have it look acceptable; strength-wise, 1.25" is more than enough, though... especially if it's .120"-wall. Here's a quick-terrible photo for comparison.
Pictured: Ceiling art.
I think that size will work. I think I also need to finish painting the garage ceiling, and I'm going to need to create some kind of flat fixture surface for welding... because I don't have that at all, currently. And that's not an inexpensive piece of tooling to buy. 🤔
Small Progress Update: I started sketching out a rough timeline and scope for the cargo rack support project - it helps when I have a project/program manager for a housemate - and the first thing on their list was "create better workspace."' Consequently, I've had to reorganize the entire garage to make a better workspace, and it's become clear that without said space, I'm not going to make any progress. So... that's where all of my efforts have been focused for the last few days; the area is in much better shape, but I'm no closer to figuring out a welding table/area. I've looked at a number of possible solutions/products/companies, but there's no clear winner...and before "just build your own!" comes up: yes, that's an option. That's my last option. I've been in one or another aspect of design, construction and manufacturing for my entire career, and if I've learned anything it's that errors always stack: your starting point will always impact your endpoint. In this case, starting from the flattest and squarest available surface is going to help immeasurably...and that's pointing me towards a commercial option. I don't really want to spend that money, but I'd rather build rack parts correctly the first time than risk building them twice...or more.
I will go with the obvious recommendation since you basically answered your question yourself....
"but 1.25"/32mm would be very useful...so that's my leading contender"
I tend to use products that check the most boxes. My top checkboxes are quality, durability, usefulness - how many different jobs can this single item do? We cannot even guess at all the ideas that you may have in store for the 3 options above, but if you are saying the 1.25/32mm will check the most boxes... 🤔 ;) :cheers:
I would go with a 1.25" to start with. Not too big for a roof rack support cage and big enough for other structural projects where 1" would not quite cut it. My tubing bender came with 1", 1.125", and 1.25" round dies; I have used the 1" a fair bit, the 1.25" the most, and have never used the 1.125".
Given time, I usually get to an answer; it's also usually the wrong one, but I do eventually find it. 🤣
That's solid advice...and I've probably already overthought the entire thing. As far as additional projects go: maybe a ladder for easy access, and I've thought about bending a not-cage for the inside, just to practice. I could maybe do some light tube work on the exterior (winch area) but that's possibly getting a little too Jeepy for me.
That's valuable input: thank you. I didn't see a lot of use for 1.125" aside from that size being comfortable to grip...but if I'm only using it for ladder rungs or the like, then I don't need a die for it.
Also, what bender do you have? I haven't ordered one yet, so I'm still in the process of overthinking that aspect of things, as well. I did jump the gun somewhat, however, and bought a pack of cable ties while they were on sale for $100.
Pictured: And they came with a free air/hydro ram! Bonus! Party on!
I have a JD2 Model 4 with an air over hydraulic ram. I bought it used for $800 with a 1” square die in addition to the dies listed above.
The only thing I don't understand, is why you don't live closer to me... 😜
I wish I lived closer to it too! Unfortunately I live about 300 miles from most of my tools right now, makes getting any kind of fabrication project done a long process with lots of time on the road.
Most of mine are still 3000 miles away from me, so I know the feeling. And I tried to fix part of that, today, in a very literal sense: I was all set to pick out a fixture table/topper and pull the trigger...so I reached out to the leading contender on my short list - Fireball Tool - to see if it was possible for me to just come pick up a table rather than having it shipped. I figured that would save some cash; I mean, they're in Spokane, so that's only a few hours away...and I can get there and back for less than the charge of the freight. Simple plan...which is probably why that's where everything derailed.
Fireball responded pretty quickly, to their credit...but they don't offer pickup in Spokane. Everything ships from Southern California, so that's totally out of the question. But, they did me a solid: they offered free shipping on a fixture table...if I ordered one today.
I don't like time-conditional promotions because I feel like it's a high-pressure sales tactic, but free shipping means a good savings on a heavy object. Problem is, I'm not in my shop/garage today to get final measurements of where I think everything is going to go...so I'm having to go off of memory, because I don't want to lose the free shipping offer. So, at length, I decided to just back off of getting an entire monolithic table and instead get the modular table they offer; it'll do most of what I need, it's nice and heavy and flat, and if I need to move it around it disassembles easily. So I checked back with the customer service rep to see about getting it, and they almost instantly confirmed that free shipping would apply to that model as well.
Then they emailed a second time, five minutes later, and rescinded that offer.
I decided to check and see what shipping would cost on the table topper; I figured it wouldn't be as bad as the $150 freight charge on a table of equivalent area and greater height...so I was surprised to see a $350+ shipping charge on the modular table topper. But, I guess that explained why they suddenly took back what they told me at first; the rep didn't understand that the shipping charges on the smaller item were much higher.
So I went to Plan B: they currently have a blemished 24x36 table on clearance...so - now somewhat skeptical - I emailed back and asked if free shipping offer would apply to blemished tops. I had already checked to see how much the shipping would be, and it was only $59...but I wanted to see what the rep would tell me. Response: "No, the offer only applies to tables." So I sent her the link to that table - which can be ordered with legs and accessories and all types of ill s*** just like any other table they have, and guess what? Free shipping offer still doesn't apply to that one. 🙄
I honestly appreciate them making the initial offer, but then reneging and telling me terms and conditions afterwards - twice - left a very bad taste in my mouth. I could still get the blemished one, since it's discounted and only $50-ish to my door...but at this point I'd kind of rather support a company that backs up their offers instead of rescinding them. That just wasn't cool.
Okay, Karen-mode disengaged. Sorry for the rant, but today frustrated me; I really wanted to support a US-based company that builds their products here, but I feel like they didn't want to help me do that unless it was on some very specific terms that I never asked for in the first place.
Time for a cold beer; feel free to fire away if I'm being unreasonable.
Edit/Quick Update: I got an automated survey email from Fireball asking about my satisfaction level in regards to my customer service. I was honest...so, hopefully someone will actually read it.
Now... I need to find another fixture option; I have two stands and about four mobile tool bases to build before I can get started on this rack project.
It may be a** backwards Using inches instead of millimeters.
but just try going to the local steel yard and asked for 1.25”/32mm🤪
All tubing here is in inches and wall thickness is in hundreds
Most likely the tubing bender will be in inches just like mine.
It’s even worse when you mix inches with millimeters just saying. 1.25”/32mm is lame.
JMHO
I’m thinking the the rubber seal is missing or flattened out under your fiberglass top and above your body, making the clearance between the top of your doors and the bottom of the fiberglass roof smaller.
I still like the idea of coming out between the fiberglass top and the body with some flat metal, utilizing the bolt holes that hold the fiberglass roof on to mount your rack.
Slight correction: most tube in the US will be in SAE/Imperial sizes, but there's a lot of metric stuff as well... it's just that most people won't be using it for this kind of thing. That being said:
JMHO
I often quote both Imperial and metric in my writing so that anyone reading this that's not in the US doesn't have to convert our measurements to their own. It's just a courtesy.
Also, I haven't dismissed the idea of pitching the rack support from the tub rails; I just don't have a good way for that to support the front of the rack, and that's my current problem to solve. My rear solution may also prove untenable...and if that's the case, I'll probably go to a rail-mount per your suggestion. It's a good idea.
I’m thinking it could be cantilevered over the front doors similar to a pick up truck Lumber rack.
Basic cantilever concepts are 1/3 cantilever, 2/3 supported
If you weren’t so far away, I would bend up the tubing on my tubing bender for you.
That was my understanding, as well. There's only one slight problem...
Definitely a lot more cantilever than is allowed, architecturally... at least without a lot of expensive work. Been there too many times. 🤣
Much appreciated! Also, maybe you can help with the aforementioned slight problem since you've put more of the little grey cells to this method than I have. We discussed the tub/top gap awhile back, and I do recall your suggestion for using thinner gasketing in order to offset the existing gasket thickness. The slight problem is that I can't actually find very much gasket thickness to begin with:
Pictured: I'm sure it's here...somewhere.
That little gap is somewhere around 1/16"... or 1.6mm for those of us that - wait for it - don't measure in Anglo-Yankee Capitalist Units. Granted, that's the view from the inside...but regardless, I'm not sure how to insert a piece of structural steel here without pushing the top upwards and creating a gap between it and literally everything else. I actually thought there was more room here, but... there isn't. This little widget, however, seems to be made from 3mm plate.
Pictured: That's 1.6199e-6 nautical miles, by the way.
I don't know how well I can sneak things in and around here for a bolt-on solution, but this is a relatively structural part on most vehicles; if I can't bolt to it - and I can't - I might be able to sandwich a plate under it, over it, or possibly weld to it.
Anyone know how to remove that plastic cover without breaking it? I need to get a look at this thing.
*cough*
Pictured: I'll just leave this here.
So, it's not that I haven't been doing anything; it's that the things I do never seem to be very easy. Thus, I spend inordinate amounts of time trying to get my little grey cells to come up with solutions that wouldn't be necessary in the first place if I just had a normal vehicle. But yeah: 73" behind the seat of a pushed-forward driver's seat of a 73-series? Not easy...but it can be done.
More coverage later; I have a bunch of pictures to go through, and then I'll start explaining all of this nonsense...and I'll probably also explain why I now have my batteries connected with a cable that's too thick to bend.
Okay, so...Super-Happy-Fun Explanation Time for what I've been doing lately, aside from that whole "being an adult" thing that sucks way more than anyone told me it would. Also, this is a LONG post with a lot of text, in which I'm attempting to explain a rather strange geometric problem...so whereas I would normally advise everyone to just skip through all of that boring nonsense, in this one case I'm going to exhort you to actually read for comprehension. If that's just not your kind of thing, though, your tl;dr is this: brackets are like, hard, and stuff.
The Great Seat Bracket Debacle: Part 1
- or -
In Which A Great Many Things Slowly Begin To Go Wrong-ish
I've spoken before about trying to create a sleeping space inside the rig; I'd like to make that happen if at all possible, and since I'm at something of a standstill on the cargo rack - mostly because I still haven't bought a bender or bothered to noodle out a front support solution that I really, truly, genuinely like - I figured that this was as good a time as any to crack into the sleeping platform challenge. I stepped back and thought about it for awhile, and I realized that my idea of creating sleeping space by pushing a seat extra-far forward - i.e. the "slider-on-a-slider" Xzibit solution - really wasn't a terrible idea. I only need about 73" or 74" of space for a sleeping platform, and getting that much requires about 6" extra inches of seat travel; that seems like a lot, but with an auxiliary set of sliders it could be doable. So, the challenge was making that auxiliary set actually fit; the only issue is that because of how the Toyota factory sliders are built, making a secondary set fit wasn't just going to be a direct bolt-in...
Pictured: ...except for the part where it was a direct bolt-in.
Uh, yeah...about that... 🤔
So, that's an auxiliary set of sliders installed on top of the factory set; done and dusted. It's not really even that noticeable of a modification, unless you know what you're looking for...and in this case, you're looking for those little .250"/6mm-thick aluminum wafers right under the upper slider. In the end, that's all it took to install a functional, locking, mostly-low-profile secondary slider on top of the factory set on the driver's side. (If anyone recalls: I was originally going to do this modification on the passenger side, but the factory slider mount spacing on that side is a different length than the aftermarket ones that I bought, and I bought those based upon the measurements of the driver's seat...so the entire plan got revamped in order to use the parts I already had.) And that's it: we're all buttoned up and finished, right there, with nothing more than four small pieces of aluminum and four bolts...except for the fact that literally none of this actually works.
Le sigh; of course it wouldn't be that easy...
The upcoming pictures will add more clarity to the reason that these spacers had to be used in the first place, but for now, take it on faith that the top of the factory latching mechanism interfered with the bottom of the auxiliary slider being directly installed onto the top of the now-on-the-bottom factory ones, so I had to add a spacer between the two in order to make the two separate slider pairs bolt together...and holy f*%$, that was a complicated description. Hopefully it made sense; if it didn't, just keep reading...or just go look at your seat sliders. Actually, yeah, do that first; all of this text will still be here when you get back.
To continue: initially, I was very reluctant to add a spacer between the upper and lower slider sets because I didn't want to add any extraneous thickness to the height of the entire seat-base assembly; said assembly was already going to end up being at least .750"/19mm taller due to the auxiliary slider mechanism being added, and my normal driving-position-height was already being altered significantly. My specific concern was that I would end up sitting too high in the seat in relation to the wheel if I kept adding spacers and sliders and who-knows-what-else, but after thinking about the issue for far too long, I finally decided that I was simply going to have to accept a height increase in order to make Slider-On-A-Slider work. I also decided that I wasn't going to make much headway on this project without creating a cheap proof of concept, and that's why I eventually just hacked a set of spacers out of a piece of scrap 6061 and bolted things into place, whereupon I immediately learned Three Very Important Things:
  1. Increasing the height of the entire seat-base assembly can easily be offset by reducing the suspension mechanism spring pressure by about 10 or 15 kilos; this allows the seat to sink a bit lower under the weight of the driver, and actually makes the entire seat a LOT more comfortable. The suspension mechanism moves a bit more at the reduced weight, but my overall driving position is effectively unchanged: win-win.
  2. Simply adding a seat slider directly on top of the factory slider didn't give me the forward travel that I desired; the auxiliary slider gained me three inches of travel both forwards and backwards, but what I actually needed was an extra six inches of travel in the forward direction only...so I needed to offset the auxiliary sliders artificially rearwards, which basically set their normal/zero point as the rearmost extent of their travel. Thus, I leave them at this "zero" and use the factory slider for normal seat adjustment, and then flip the auxiliary lever to create a 6" movement forward; paired with the 4" that the factory slider give me, this creates a total of just over 10" of possible forward travel...and that makes a rear sleeping platform just barely possible.
  3. Decoupling the factory sliders from the seat frame and/or base and then adding a secondary plane of travel creates a perfect recipe for jams, binding, and overall non-function, so this entire plan is actually made of pure garbage.
So, that last point might not be exactly clear. Here's a breakdown of the situation, in detail:
Toyota was smart when they designed the factory sliders; they are a disparate, paired unit that uses both the seat frame and the seat base as the slaving mechanism that couples the upper and lower tracks of each slider together, side-to-side. This saves weight, reduces complexity, and allows a single locking mechanism to control both inner and outer slider positions while also ensuring a small degree of fitment adjustability between the seat base and frame...but this little bit of brilliance also means that the sliders are no longer fully slaved together if either the seat base or the seat frame is removed. At that point, one portion or another of either slider can move independently of the other, because there's no structure between the upper and lower travel planes of the factory sliders aside from the seat frame and the seat base. I'll state this again, because it was the part that was the hardest for me to get my tiny little mind to recognize: the seat frame and seat base are the horizontal structures that couple the factory slider tracks together, side-to-side. Thus, when I added the secondary/auxiliary set of sliders on top of the factory set, I accidentally caused a permanent decoupling of one portion of each slider, relative to the other; specifically, I decoupled the mating surface between the lower track of the upper slider and the upper track of the lower slider. This created a floating, uncontrolled pairing of tracks which could move independently of any other function; technically, this happened on both the inner set and outer set, but since the factory locking mechanism still interfaced with both outer sets, there was always a control point between the upper and lower track of the factory slider on that side. However, as stated: that mechanism doesn't exist on the inner side of the factory set...so even though the auxiliary slider has its own locking mechanism on both sliders, the factory inner slider was still floating...so when the seat was moved through its range of travel, the factory inner slider had a habit of moving independently of the outer, taking the lower track of the upper/auxiliary slider with it, and then jamming at one extent of travel or the other. Also, because of how I mounted the auxiliary sliders in my proof-of-concept build with the aluminum spacers, the control handle for that pair's locking mechanism had a persistent habit of flying loose when the inner slider moved out of alignment...because of course it did.
Okay...that was a long, unclear paragraph; if you're still reading and you want to better understand this issue, go take one of your seats loose and look at how the upper part of the inboard slider can move around wherever it likes once that upper plane of control is removed. It can do this regardless of the latched position of the outer slider. Now; imagine that movement compounding via a second iteration of the same being added into the mix; that stupidity is what I accidentally created, and it's why the slider-decoupling-and-jamming problem - and thus the entire secondary-slider project as a whole - is actually pretty easy to solve: all that's needed is a bracket that couples everything back together, both vertically and horizontally. Once that bracket is in place, the factory slider latch can control its slaved inboard unit and the upper sliders can function in any orientation without jamming (or without the handle flying loose) and everything works as intended.
Unfortunately, that bracket is not very easy to build...because of course it isn't.
Way back in the Before Time, someone suggested that I use a couple of pieces of flat stock to make an offset bracket to solve the seat-travel issue; this wouldn't have fully worked for me - the travel extents would have just been shifted, but not actually increased - but it was a solid suggestion and it gave me the idea to start with flat stock for the bracket that I eventually realized I needed to build...and that would have led to a very simple build, had I not decided that I wanted to use angled stock instead of flat stock, because of 1) extra strength, and 2) reasons. The use of angled stock complicated things immeasurably, because even though angled stock is pretty easy to find, do you know what isn't easy to find? Angled stock that's 1.500" x .625", which is exactly 38 by 16 metric mini-feet for those of you elsewhere on this rock. It's a weird dimension, but that's the size I needed said stock to be in order to fit into the stupidly-tight confines of the factory seat/base/slider assembly without hitting anything. And that's how I ended up creating this weird little cutting jig...
Pictured: Much like the rest of this rig, it'll work until it doesn't.
...whereupon I realized that holding said guide in place was actually a lot easier than I thought it would be. You see, not only do I have a welder, but I kind of know how to use it.
Pictured: Which is a phrase that here means "I don't know how to use it at all, but nothing I've made has broken. Yet."
Tacking that cutting guide in place was probably the only smart thing I did on this build. Normally, I would have then tried to get an action-shot of a grinder cutting things apart: if there's anything we've learned from Project Binky, it's that grinders and brackets and showers of sparks solve literally everything...but I didn't feel like sectioning a part of my body accidentally, so there are no action shots. Instead, you get a portrait-mode end-profile shot that shows what happens when I forget that I'm supposed to be making dinner and instead just keep playing with a hand file.
Pictured: Too bad I have to weld over some of those curves, soon.
So, why was all of that ripping necessary? Well, it wasn't...except for the fact that this piece of steel mounts angle-down, and it wraps around the rather obtrusive factory control latch mounting bracket that caused all of this headache in the first place.
Pictured: Shown here, obscured by Kirby-flavored washi tape.
Okay, remember when I said that I was using angled stock for extra strength and reasons? I wasn't kidding: that pink, taped-over triangle is the reason. As stated, that's the mount for the locking mechanism and it's the entire reason that a spacer of some sort is necessary: the auxiliary slider has to mount directly over the top of this piece...but it also can't occupy that triangular area while doing so. The simple solution would be to two-piece this side of the bracket and avoid cutting around the mount entirely...and if I wasn't also making this an offset bracket for the sliders, I might have been able to get away with that simplicity. However, since I do want to offset the upper slider approximately 3" in order to make the seat move an extra 6" forward, I wanted a full and uninterrupted piece of steel holding everything together on this side of things. A piece of flat stock being cut around this triangular projection would have been seriously compromised unless it was so wide as to introduce other issues elsewhere...so that's why I line-ripped steel into such a strange dimension, and that's why I then patterned it (pink tape) and took way too long cutting and fitting it.
Pictured: But the result was pretty damned good.
I actually did a bit more filing and filleting after I that piece was fitted into place, but I didn't photograph it; regardless, the end result was a piece of steel that was of a decent size and the appropriate thickness which not only fit around the offending metal triangle, but which is also strong enough to not be compromised in the event of a collision or rollover. In that regard, .250"/6mm steel is WAY overkill for this - I mean, look at the thickness of the factory parts - but since I needed a .250"/6mm spacer to clear the factory latch mounting bracket, this was the easiest way to create it; going thinner would have been possible, but I'd have needed spacers or something else that would have added needless complexity...and I already had .250"/6mm angle in stock, so that's what was used. Here's the full-length shot:
Pictured: Starting make sense, yet? No? Good.
I did this outer piece first because it was the hardest; that triangular cutout was a pain, and I knew as much going into it. The inner piece should have been quite a bit easier, but when I rough-cut it and brought it over to check the basic fit and clearance, I found a rather interesting surprise.
Pictured: "Missed it by *that* much..."
Yes: that is the lower end of the seat-return spring bracket. Also, no: it cannot simply be bent out of the way...and I know that because I tried. There's just not enough clearance or material strength to re-contour that bend without possibly bending or breaking something else that's adjacent. In full disclosure: I knew this piece could likely be an issue, and I thought I accounted for it, but evidently I missed a measurement somewhere along the way and as a result I didn't realize that my custom-dimensioned angled stock was still going to interfere with it...and I'm pretty sure that's where I stopped for the night. That means this is probably a good point at which to end a very complicated post...and that is a phrase that here means "to immediately go back through everything I just wrote in a vain effort to edit it for clarity and errors, because it would be hard to explain all of this more poorly than I've done."
Ugh, the things I do to avoid setting up a tent...
To be continued. 👍
Yes: that is the lower end of the seat-return spring bracket. Also, no: it cannot simply be bent out of the way...and I know that because I tried. There's just not enough clearance or material strength to re-contour that bend without possibly bending or breaking something else that's adjacent. In full disclosure: I knew this piece could likely be an issue, and I thought I accounted for it, but evidently I missed a measurement somewhere along the way and as a result I didn't realize that my custom-dimensioned angled stock was still going to interfere with it...and I'm pretty sure that's where I stopped for the night. That means this is probably a good point at which to end a very complicated post...and that is a phrase that here means immediately go back through everything I just wrote in a vain effort to edit it for clarity and errors, because it would be hard to explain all of this more poorly than I've done."
To be continued. 👍
Nice work !
I did not read the content but I get the idea :p
Nice work !
Thank you, but just wait until the part where I totally screw it up.
I don't blame you; that was a lot of words, and words is hard. What I should have said is "Let me tell you why I suck" and then just posted a bunch of pictures and talked about how things look so much easier to do when you're watching a professional do them on YouTube.
I was in the trades for over 45 years so I know when I see good work and when someone is taking the extra steps to get it right. ;)
