Don't sweat those knuckles, just run them. Blasting the threads isn't a big deal either.
I agree the powder coat inside is fine. To me it looks like when blasted, the threads were not protected. ? To me that is a no-no. Not that they will not function, but I am particular on threads and machined surfaces.
This might be regarded as an old performance benefit, or "speed secret" if you will. Builders of NASCAR engines used to paint the insides of the engine blocks in an oleophobic paint to expedite oil drainage down to the sump. In a chassis part, I'm not so sure.
Recommended by many high performance engine rebuilding books, Glyptal seals the tiny ports left in metal after bead blasting and leaves the engine block interiors smooth. Helps keep the oil clean and flowing freely. Acid and oil resistant. Used on generator and alternator armatures. Glyptal has great electrical insulating properties too!
Exactly why machined surfaces should not be sand blasted. The result is NOT a smooth surface after sandblast. It may work in a rough environment but It is so easy to avoid messing up machined surfaces.
