Builds Outsane/Solvefunction/Cruisin2Camp Build
Installed a radius fab snorkel I got from Long Range America.
Holes and clearance left from the ebay snorkel
Thus us the temp fix for the connection from the tube to airbox
That’s a good idea for a connection. I got that same long entry snorkel and just couldn’t get the silicone to connect to my airbox so I got a mid entry instead and will try again. Mind sharing a pic of the connection from snorkel to airbox?
This is the current connection.
There are plans to make a full 4in connection that will require some cutting.
Drove 1000 miles or so to Las Vegas and back.
On the way there I could feel a miss fire that was intermittent.
P0300
Pulled over checked spark plug wires and distributor cap for any loose connections.
Didn't find anything kept driving, bad gas maybe?
Then it got worse and more consistent...
Crud.. started calling auto parts stores on the way. For plug wires and ignition parts.
P0306
Ok so now the misfire is one cylinder .. head gasket, spark plug.
P0171-Lean bank 1
Pull over 2 min from orielly at a Lenmoore high-school parking lot where they have plug wires. Look again in the engine bay for issues.
There you are you glorious Mother trucker!
This is to the jumper for injector #6
For the upgraded fuel injectors.
my kid had to poop.
Recrimped the wire while getting rained on.
Ran strong to Vegas and back home.
Having the ultragauge helped a ton to give me insight into the issue.
Great detective work !
Outsane, The rear hitch should not be used for much towing. That 4 bolt bracket ties the two rear bumpers together. No link to a frame member. If memory serves. Plz. double check.
I didn't use it for towing, just holding bike racks
The rear upper link mount to the frame had some slop in it. I used a bolt that was too small in diameter and was supposed to replace it and never did about 40k ago.
I made some plates and welded them in.
Also replaced the printed bushings. They were all dry and not as tight. The continous rotation had worn away the tpu so the insert had some space.
oh boy.. ive listened to all the podcasts about this, seen it on IG too, but looking at it here makes it worse.. I'm glad youre okay. Ive also seen your repair strategy/parts too, itll be a bittersweet time, but itll be better once its done..
