First gen IFS box AFAIK. There are some that have a vacuum switch in the top of them. Doesn't matter if you use those or not, but I don't think that I'd hook it up.
I'm not a good source for who to buy steering arms from. For my use high-steer is pointless, and that is what all of the bolt-on arms do, and they all specify a lift higher than I had. I built an old school cross-over RS steering arm and then stumbled over it on the garage floor for half a decade or more before I put it on. Had to modify it severely. It's a real trick to get the drag-link to clear both the oil pan and the top of the RS OME leaf spring without resorting to limiting travel in either direction, but it can be done. Going taller lift might have made it easier, but if anything I wanted the truck to be an inch lower than the OME's.
I used Marlin sourced link tubes & FJ80 TRE's.
