For Sale Okinawa, JP: Chopped LS swapped 94' Toyota Landcruiser
Year
1994
  1. 80 Series
Okinawa, Okinawa Japan
Mileage
12345
Color
White
94" Toyota Landcruiser, with a LQ4 LS (6.0) engine/4L80E Transmission. Chopped with custom tray, 4" Radius Snorkel/airbox, 4" lift, 37" Maxxis Trepador tires.
Recently retired and moved to Okinawa, Japan. I imported to Okinawa for the US March 2025, but due to the LS swap (not having the title for the LS, and whatever other rules they havr) the Japanese government will not register the LC without me paying them to tear the enginedown, rebuild, and also paying them for storage while they do it. In the US this LS was street legal and register.
I'm retired, so i have all the time in the world. Sits in driveway under a car cover. I have a build page with everything from purchase, chop, engine swap, to current: Builds - Project Rehab (Chopped LS Swapped 80 Series) - https://forum.ih8mud.com/threads/project-rehab-chopped-ls-swapped-80-series.1286025/
Asking $25,000. Negotiable due to shipping.
Most of the specs -
Engine/Transmission:
- Gen III 6.0L engine (LQ4).
- BTR Stage 2 Truck Cam Kit.
- Michigan Motorsports Timing Chain, Cam Sprocket, Crank Gear, and Dampner.
- ARP cam bolts 134-1003.
- Michigan Motorsports LS7 Lifters Set.
- Wiseco Pro Tru Street Pistons.
- Brian Tooley Racing LS9 Cylinder Head Gaskets MLS Pair Turbo Multi Layer 4.100 Bore.
- Melling 10296 oil pump.
- Michigan Motorsports Camshaft Thrust Retainer Plate.
- Mark's 4WD Oil Pan and Sump pickup kit.
- ARP 134-3609 head studs bolts.
- Gates 160° thermostat.
- ICT Billet LS Truck OEM Location Alternator/Power Steering Bracket LQ4.
- 4L80E Transmission.
- Mark's 4WD Transfer Case adapter.
- ARP Bellhousing Bolts ARP-134-0902.
- Selkirk Off-road motor mounts and crossmember.
- Walbro GSS342 Fuel Pump + 400-766 Installation Kit.
- PSI wiring harness.
- FIC 34LB truck injectors w/adapters.
Suspension/Wheels/Tires:
- Slee Rear bump stops.
- Slee Front Swaybar extensions.
- 17" Steelies.
- Method NV 305 titanium 17" wheels.
- 37" Maxxis Trepadors.
- Landtank extended rear lower control arms.
- Dobinsons adjustable lower upper control arms.
- Dobinsons adjustable front panhard.
- Fox 2.0 shocks.
- RVC Chromoly front axles.
- Slee Billet Front Control Arms.
- Slee 4" springs.
- Land Cruiser Phil's heavy duty rear swaybar links.
- Tatton front and rear double cardon drive shaft.
Body/Bar work/Recovery:
- Chopped.
- Sunroof delete.
- Antenna delete.
- Quad headlights.
- 4x 4x6'' Demon LED Headlights Kenworth Freightliner FLD120 Peterbilt 379 378.
- Custom tray
- ARB bumper.
- Warn M8000 winch.
- White knuckle sliders.
- 4pc 4x6 RGB LED Headlights Hi/Lo DRL.
- Toyota Pickup 2 Door Standard Cab 1984-1995 back window.
- Raptor Lined (tintable), bright white with metallic flakes.
- Rampt Customs front axle truss.
- Arcworxs knuckle gussets.
- Barnes 4WD short receiver tube.
- custome flare guards.
Interior:
- Glove box grab bar.
- Wit's End fire extinguisher mount.
- Lizard Skin sound deadening and Ceramic Insulation.
- MAT66 ProBlack Car Sound Deadening Mat.
- TruFit vinyl flooring.
- Corbeau seats.
- Element E50 Fire Extinguisher Roll cage Mounting Bracket Kit.
Electronics:
- Dakota Digital GSS-3000.
- Dakota Digital SGI-100.
- WOLFBOX G850 4K Mirror Dash Cam,12'' Mirror Dash Cam Front and Rear.
- ATOTO S8 Ultra 10.1.
- Scan Guage II.
- Viper alarm system.
- Auxbeam 8 Gang Switch Panel GA80.
Flaws:
- No AC. Everything is plumbed up with freon, but i think the evaporator is clogged.
- Its loud (exhaust routing and muffler will fix).
So is it back in the US or japan still? I assume bringing it back isn't included in price
It's still in Okinawa. . .l can talk numbers to serious buyers.
I also think it'll be a little different because it's coming back to the US.
I honestly think that message was just a little bit of hate because he's getting no hits on the LC he's trying to sell for a +$20k profit.
Which cruiser? My I paid $35k for my factory 5 speed FT 80 and put another 20k into it. With receipts. Thanks.
Just imported another vehicle and paid 12.5% Tariff on it.
10% new blanket tariff plus the original 2.5% tariff. I’ve imported over 30 vehicles from a number of countries over the past few years.
What you “think” is irrelevant as you clearly have no idea what you’re talking about regarding to importing. Which is why you imported a vehicle without even knowing the laws there and why you’re currently sitting on a brick you can’t use.
Have fun
@AdamFire
You right. I don't know s*** 🙃
On my ad, please ask questions if YOU are trying to buy, then DM me for negotiating.
If your not trying to buy. . .thank you for viewing th ad 😉
I have seen (and wheeled with) this truck in person. It is spectacular...and Darren is a straight-up guy. Buy with confidence.
Evening from Kadena. Awesome looking build. Its probably a pain in the ass, but you might try advertising on base to one of the service members that is PCS'ing soon back to the States. The Navy pays as I'm sure you're aware. Only problem would be getting that US title in their name for the transfer.
Best of luck on the sale, that thing is a steal compared to the rusted, repsrayed, Prados these dealerships are slinging out of the gate.
