OEM TYRES & RIMS
What’s your point, do you think 6PR is always LT-type? I’m not sure.
Thanks for the Truck :)
I assume that Toyota used a standard numeration for the tyres (without exception for 9.00-15-6PR)
I also assume that the sand tyres have to be large and wide (on top of the special tread).
You can observe the difference to the standard 7.50-16
You can also google “9.00-15-6PR sand Tyre” and see that it’s not a vintage cookie
I believe that the sand tyres 9.00-15-6PR is a large one (around 33”, depends on the model)
I’m looking at buying a set of BFG all terrain 33x10.5R15s next week for my 1983 factory rims. I wish that BFG still made the 9.5” wide tire. I hope the 10.5s will fit my rims
I wonder which of the original looking tires 7.50 R16 are still available on the market?
My search
From Dunlop Major Trak “family”:
Dunlop Universal is not in production anymore (stopped in 2018)
Swallow S-262 (Indonesia)
Tiron HZ2A (Korea Indonesia)
Chengshan csh-64 (China)
In Bridgestone Jeep Service “family” the is a Firestone Jeep Service from Africa
Dunlop SP Sand Tires
7.50/16R 5 Lug from HZJ79's
Split Rims....
If anyone wants 4 split rims let me know....ideally can trade something
Looking to put the tires on my CDN101
@Economist LC76
You have mislabeled the Michelins in post #10... the first two pictures are the XL not the XS, the XS staggers the pattern 3 lugs, 4 lugs, 3 lugs, 4 lugs (depending on size it could also be 4/5/4/5/etc. .... the XL is always 3 lugs
you can see the XL labled as #2 in post #9 the XS is #3 in post #9
Hope that helps... great thread!!
I’ll post this here for posterity - BFG has a KM3 M/T in 7.5R-16. The best part is, you get all the advantages of a radial tire, and can keep the “stock” look. You need to step up to a 16” rim, of course. but City Racer offers these. They measure out to be just over 30” tall on the truck and about 8” wide.
They should be near 32” and are too, regarding to BFG specs:
SPECIFICATIONS
7.50R16/E 116/112Q
21105
Mileage Warranty
Section Width on Measuring Rim Width
8.70" on 6.00"
Eco Feature
Tread Feature
Overall Diameter
31.8
Max Load, Single (LB @ PSI)
2755 @ 80
Sidewall
Raised Black Letters
Revs/MI
654
Tire Weight
50.46
Rim Width Range (Min/Max)
5.50" - 7.00"
Tread Depth (in 32nds)
18.0
They sure should - but like most BFGs they run small - then put the weight of the truck on them and they measure out to about 30.5”
That’s the only reason I brought them up. I bought them to be a tall, skinny tire option but they’re not nearly as tall as advertised which makes them a nice reasonable size for the “stock” look.
In BJ42, the original tire is been Bridgestone Jeep Service 7.50-16LT.
