Like the 'mass backing' on ACC carpets?Yeah plenty of companies all over the internet. It's just butyl with a layer of foil on top. Make sure you look at the thickness of the sheet though as thats how the super cheap companies scam you and the most important factor. "Dynamat" is good for stopping resonance of panels but doesn't do a ton to actually block and absorb sound. You need mass loaded vinyl or closed cell foam for that.
By itself, Dynomat-like will offer only very marginal improvements.I don't think the dynomat type does anything fir a 80. 80 emits lower frequency noise. Dynomat is for higher frequency.
You can think that, but It does make a considerable difference in road noise.I don't think the dynomat type does anything fir a 80. 80 emits lower frequency noise. Dynomat is for higher frequency.
You get diminishing returns with any of the adhesive matts as you get closer to panel edges, but that doesn't mean it's bad to do. The foam should be 100% coverage as it doesn't work as a mass damper.I used Noico as well. It is just foil-backed butyl rubber. Don't over do it with coverage.
Weird the downvote...You get diminishing returns with any of the adhesive matts as you get closer to panel edges, but that doesn't mean it's bad to do. The foam should be 100% coverage as it doesn't work as a mass damper.
Thanks--but about that decibel monitor thing. Great idea but engine in the shop, so the only measurement I can take now will be vewwwy qwiet...By itself, Dynomat-like will offer only very marginal improvements.
In my 2016 Tacoma I applied the following (in doors, cab wall, 2nd row floor):
- B-quiet ultimate
- 1/8" or 1/4" closed-cell foam
- 1/8" or 1/4" mass loaded vinyl
The MLV made the biggest difference, but given its thickness and weight it couldn't be applied everywhere. The above setup did make a very significant difference on that Tacoma.
OP, I suggest you install a decibel monitor application on your phone (such as "Decibel X") which measures and and records sound frequencies. Turn the app on, go for a drive, and see what kind of noise you're dealing with. The above products can make a very significant difference for high frequency noise, but will do little to nothing for low frequencies. I recently went through this process while attempting to build a portable sound-deadening box for my generator. The fun starts here in my trailer build thread on ExPo. There are more related posts later in the thread, too. Have a look, you'll likely find information useful for you.
Is this foam? …Going back to your original question, my girl got Mega Mat installed along w mass backing carpets.
A couple things…my installer had a helluva time getting the carpet to sit right due to the thickness in the drivers footwell. And you’ll need the extender nuts to get the foot pad things to bolt down right (delta has them) in the back seat entry. Also, the accelerator pedal seems to bottom out before it really does. Again, due to the thickness. At some point I’m going to mess the padding there to see if I can slot it so it doesn’t interfere with the pedal.
As for sound, it definitely seems quieter, especially at freeway speeds and the doors close with a very solid ‘thud’.
