Builds New project, 1969 fj40
The home made tool. The one I have apart is the small thread and the last is the large thread plug B4 modified. The porcelain part is the same size on both plugs.
I found the quick disconnect coupler fitting on my compression tester hose fits the air hose couplers too. All you have to do is remove the Schrader valve on the other end of the hose to allow air to flow thru it, so you can supply air into the cyldr.
Took a still from a video. She’s cranking and no weird noises yet.
I need a throttle cable and starting fluid.
I think I screwed something up.
I shot some starting fluid down and it cranked and stumbled.
Then I realized I never attached the coil wire. 🤦🏼‍♂️
Tried a few more times and never stumbled or fired.
Now it bogs down when cranking.
I pulled the valve cover off and there’s no oil to be seen on the valve train.
I’ve cranked it for probably a minute or two all total.
It is getting fuel now.
Muck fe this is frustrating.
Corey, it takes awhile for the oil to flow. If I recall, #4 TDC, spin the oiler with drill, oil will then OOZ, not really flow. Bogging may be as simple as a low battery 🤞
Give Nic a call in the a.m. (I think you had the heads done at Yoda1(?)
When you say it bogs down have you pulled a plug or two to see if it is flooded? Even if was flooded it would not bog down as your valves are working so it will blow the unspent gas into the tail pipe. I agree with Fireman you need to just keep cranking it with a fully charged battey. If you have a multimeter check the resistor at the coil and let us know wht the resistance is. Then check the coil itself for an open or short. (PS: Turn the coil over, looks cool but it is directional) Test between the (+) and (-) on the coil it should be between .04 and 2 ohms. Now check between the (+) and the Primary (spark wire to distributor cap) and you should have 4000 to 6000 0hms. If the reading is zero the coil is shorted out and needs to be replaced. Check the distributor points and make sure they are opening, check the gap of the points they should be .018 on top of the distributour lobe. (take out # 1 plug and put your finger in the hole, turn the engin until air tries to blow past your finger, stop right there, now manually turn the motor to set the timing mark to 7degrees BTDC with the advance unit fully advanced. You will be static timed right there. When it's running you can time it with a timing light at 650 rpm
I got home today, pulled the accelerator thing on the carburetor (no cable yet) a couple times, tried the key and she started and ran for ~6 seconds.
Charging the battery to try again, and rotated the distributor a scoche based on advice.
We’ll try again tomorrow, but it was so good to hear and see!
I may have a starter issue? The battery is charged, everything is oiled and it just struggles to turn over.
I hope it’s just that anyway.
Just a thought, you can pull the spark plugs and see if the starter spins the motor free without any resistance, basically checking the starter for flat spots in the armature or commentator. Have you insspected the timing chain ?
Timing chain?
I have pulled the plugs, motor turns over without them.
The starter will eventually get the motor turning but it just struggles to do so.
Can’t really explain it very well I guess and I can’t post videos, so...
I was optimistic when it ran a couple days ago but I can’t seem to replicate it.
time for a srarter yes. x9vhkjp-toyota-land-cruiser-starter.html
$37.00 can’t be right?! Almost worth risking it as they must have forgotten a 0 before the decimal point?
Straight off the internet, Parts Geek. It is a remanufactured but it is waranteed. I don't know if it required a core to be returned. Looked at it and it is a $38 dollar core charge so ship your old one back to them after you install the new one. I put it in a box and send it USPS, tell them it's media, books and it is a flat rate cheap. Check local and see what they get too.
I don’t think it has any affect on it starting, but I had some hoses hooked up wrong. In my excitement last week I just started throwing it back together... I had the transfer case vacuum thing going to the carb base and the oil filler hose going to the manifold.
I happened to be looking at old pictures for something else and saw my mistake.
Anytime your working on the valvetrain, pour oil over the rocker arms and valves before you put the cover back on. Heck, get one of the old oil cans with the trigger and go to town like your valvetrain is the tin man. This practice should be performed on any engine, when you've taken components apart that normally have oil and you've cleaned them of their lifeblood. This is also a good practice when starting an engine that's sat for long of time. There wont be oil up there until the engine is running, so you need to supply it manually to protect these components until that normal operating condition exists again. When you do get it started, immediately verify oil pressure.
