Thanks for clarifying regarding the bolt/nut orientation. So nut on top on driver side. Same with passenger? I’ll delete the misinformation above.
Please re-read my post carefully.Thanks for clarifying regarding the bolt/nut orientation. So nut on top on driver side. Same with passenger? I’ll delete the misinformation above.
Thanks for that.Just popped in to tell you that I dropped off your parts at UPS this morning, and to say thanks for the insulator. Maybe in spring I will get a chance to install it on Ruftoys and post a pic or two.![]()
I don't see washers on the top in the images above. Are you saying the passenger side bolt head rests directly on the insulator with no washer and it is upside down in the image too?And the saddle of the passenger mount gets wallowed out by the HEAD of the bolt facing down.
Agreed. There is a higher level of logic in your thinking than in the actual design of the system.I pretty sure that I employed a washer between the head of the bolt and the insulator. Washers are your friend when working with bolts. There is not enough surface area under the bolt to not dig into the insulator. I see SOR has their bolt uses a washer below but not above.
It all seems wrong, to me. The original bolts were more like the material that the frame is made of, steel (they say 5 on top). The replacements, they are medium carbon steel and underwent heat treatment. Although greater in ultimate yield strength, higher Grade (SAE) or Class (JIS/metric), are known to be more subject to fatigue. Cyclical loads, loosening of the bolt by eventual compression of the insulator, and normal automotive corrosion will foster stress cracks to propagate, over time.
My rule of thumb, not printed in any service manual, is before every wheeling trip, I reach in through the fender on the driver's side and try to turn the upper insulator by hand. If it moves, I do a full systems check. This has worked for me for decades. Problem is, not so many people wheel their rigs anymoreso the rule of thumb isn't as useful in those cases.
We did that too. Haven't found any lost treasure, unless you count the acorns.On mine, I used this as an opportunity to vacuum out the frame rails...
Never mind!! I was disoriented and did remember that this is the rear mount!Well, crap. I didn't check the mounting bolts that go into the engine block. The old engine is 10mm new engine is 12mm. I'll go get the right bolts and drill out the motor mounts to suit.
My question is about the fit of the "new" square design front mounts. The conical section is larger than the hole in the front mount. Do I have to enlarge the hole there too? (Or does it rest on the shoulder?) Also, it there a "right" orientation for the square mounts?
Mine is hitting the bottom edge of the radiator. Going to try and remove the chassis pads and see if it drop enough.I left all of the F mountings alone and I run a clutch fan on the 2F. It’s close but works okay no overheating or rubbing
I removed the pads and that bought me just enough clearance to get everything tightened up. The fan is “close” but it does not hit the radiator.Mine is hitting the bottom edge of the radiator. Going to try and remove the chassis pads and see if it drop enough.
I realize that. I have trust issues.The pressure plate is keeping the friction disc supported / held in place.
