Normally, I just ignore comments like these, but you're wrong. The FJ40 is fulltime four wheel drive. The transfer case only has a high/low selector lever, meaning both axles drive the vehicle. Always.
The only way an FJ40 is not fulltime four wheel drive is when the front axles are fitted with locking hubs, removing the left and right driveshafts from engagement. To my knowledge, North American FJ40 front axles were fitted with lockout hubs as a dealer installed option.
You can argue, as many people have over the last several decades since locking hubs became commercially available, that they have benefits. The only real benefit locking hubs have is profit for the manufacturers supplying them. The ring and pinion in the front axle turn regardless of whether the driveshafts in the axles are connected to the wheels or not. The argument that there is no load on them since they are not connected to the wheels, and therefore do not wear, is wrong. The ring and pinion gearset is hardened to prevent wear and strengthen the overall gearset. Normal driving loads present no more wear on the front gearset than on the rear gearset.
As to increased mileage, I've never seen proof of that.
Well, I'm glad you didn't ignore my
wrong comment
Post a pic of your dash/shifter or better yet your actual t-case. If you truly have a full-time 4wd 4x Series transfer-case, it's absolutely the rare exception, not the rule. And if that is the case, I would love to see it! I've seen the 2wd 4x Series t-case but never a full-time. What is it using to balance front-to-rear? A center-diff? A viscous-coupler? Educate us!
The rest of your comment isn't worth disputing as it's both inaccurate and misleading. Toyota offered free-wheel hubs from the factory starting in the 70's and they were standard from the factory for many markets by the early 80's and continue as a factory option on part-time 4wd variants to this day. Additionally port/dealer installed hubs and end users hubs were extremely common and are to this day for a reason.
I've never claimed it's a performance upgrade, but for longevity of parts it's an absolute no-brainer. Additionally vibration and noise, particularly noticeable in old ball/claw Cruisers or those lifted. Run 70 mph with hubs locked down the highway in an old Land Cruiser, you'll generally know the front-end is
NOW spinning
I've spent time in and around 1000+ 4x Series around the globe and from around the glove over the past ~30 years. We have numerous 40, 41, 42, 43, 44, 45, 46 & 47 Series models in the collection at the Land Cruiser Heritage Museum that I regularly spend a great deal of time around. All part-time t-cases, some with drive flanges and others with free-wheel hubs. I stock new 4x/6x/7x OEM Toyota t-cases, stock and build used t-cases, etc... all part-time. We also stock 8x/450/100/470 t-cases in their full-time HF2A variant. I'm quite familiar with Land Cruisers and their t-cases.
I kinda have a thing for the history of many things Toyota including hubs
The common 4x Series PART-time tcase fwiw
