missing something?
That's not a dashpot. That's a diaphragm.
I know that you are the king of parts, and I have bought many from you, but you may want to stick with EFI. carburetor diaphragm - Google Search
No, there are two on there for the alternator / water pump. He's good there. I thought the same until I looked closer at the left side of the pictures.
This will be a tough one to do. It is an abomination of multiple versions.
I'm going to throw out an idea here, but a couple others need to chime ion and advise their thoughts.
@NLXTACY @Tools R Us @scottryana @inkpot
If the engine is dying or idling down after warm-up, I'm thinking that the computer is hitting "closed loop" temp designed for the fuel injection setup. Since the carburetor is there, does the computer adjust timing or anything that would affect this in this situation? Is the choke adjusted properly?
I also like what @artech posted about changing the neutral safety switch and bypassing it to allow it to be started regardless of clutch or shifter position.
I would also change the automatic choke to a manual choke. A throttle cable with a pull knob from a tractor or the like will easily substitute here.
Good luck!
, I did not realize he had a cobbled rig, and if you need a pick up tube the proper length is 5 3/16 " I have made few for the diesel swap, also just put an inline, fuel filter, trying to get the stock sock filter to work is a huge task, and it probably not function very well or at allOk, for clarification. You drive around and have no issues until your engine is warmed up, then you have idle and running issues, stuttering at speed and eventually a flooded carburetor? Your vehicle was originally a 1FZ-FE from the factory but was converted to a 1FZ-F carbureted engine? Now comes the question for you. I can see you're runnning a mechanical/ jack shaft driven fuel pump and it's shiny and new looking. Does it still have the electric fuel pump in the fuel tank? If so then that could be your issue. The electric fuel pump is going to overpower the mechanical unit in delivery rate and flood your carburetor. If the pump is present and not plugged in, your mechanical pump could to pull fuel and receiving large quantities all at once versus a steady flow rate. I would start by figuring out the in tank pump situation. If it's there, remove the electric punp and replace it with a piece of copper or aluminum tubing and the original filter sock and see if things change. If your in tank electric pump is already removed and no longer an issue, you may need a carburetor rebuild. You may have clogged Venturi's or bad float needle valve or even a bad float. Honestly, after checking the fuel pump situation you may want to find a factory service manual that outlines proper carburetor adjustment and timing for a carbureted engine. Timing for a carbureted engine will be a different specification than that of a fuel injected engine most of the time. Check back afterwards and let us know how things are going.
Update #1
I just picked up my car from the 8th mechanic with whom I tried my luck. And, surprisingly, things improved in a way. With linited time at hand, he said he rather superficially checked and cleaned some things (air filter, petrol pump and carburator) and corrected some adjustments of/related to the carburator. He complained that this car has seen too many mechanics ...
I should come back in a couple of days, he then would dismount the entire carburator and check each of its components. He will also work on the wiring. I asked him about the electric in-tank pump which he said had been removed before. In sum, when I return my car in a couple of days, I will ask him to work through the suggestions some of you have made - thanks a lot for these!
For the time being, the result is that the car runs more smoothly and does not die anymore - except for the situation when I slow down to the point where I have to shift into the 1st gear, then the rpm still drop sharply and the engine would die. So, whenever I had to do that I let the engine run idle and operated the brake pedal and throttle simultaneously to avoid that the car turns off. Not very comfortable to drive, but it works. Once I accelerate again, the engine would run smoothly and not die anymore as before.
I keep you posted.
