- Thread starter
- #61
I'm assuming you posted your last post and hadn't seen my revised diagram? @sbman
Dang, I would have jumped at that in a second. But it's pretty amazing what you can get for your money now a days. I bought a JYE DSO 112A a couple of years back for ~$60. (Still available on Amazon.) It's got a touch panel and color display, with Vmax of 50v peak. Certainly not as powerful as a Rigol, but for $60 hard to go wrong.I threw away a Tek 555 O scope because nobody wanted it for cheap or free. I have a smaller one now.
This is the challenge, switching the transistor fully on ("saturating" it) without burning it up. We don't know the resistance of the VSS circuit, so how do we select the base resistor? We'd have to make the circuit more complex to isolate it from the unknown.Also, the resistor you show on the base lead of the same transistor in your circuit, 10 ohms, is pretty low and may lead to destruction of the transistor.
Thank you SmokingRocks for your proper reply...well...following your instructions...made an electronic guy check the speedo circuit and found a cut off cable that leads to the speedometer needle coil...the speedometer begun to work again all right, but there is a fail code leading to the cruise.control ecu says no speed sensor signal...there is a black/red cable that seems to deliver some kinda of signal from the speedometer to the cruise computer, the tcm and de ecu, and again seems there is the problem, no signal or maybe as in your diagram, could it be some kind of problem realted with the ccu ecu and that diode in the computer that is blocking the signal...???If the speedometer is not working and the ecu isn't getting the VSS signal then the issue is your VSS 1 or VSS 2 sender units or the electrical pathways.
The speedometer can be broken and the ECU will still see the VSS signal ONLY IF the VSS are actually sending a signal. Download your FSM from the link in my signature so you can follow the electrical wiring diagram to troubleshoot.
How are you reading a code from the cruise control ECU? I am not aware of that ECU having any function to do so, there is no data connection there to read from.Thank you SmokingRocks for your proper reply...well...following your instructions...made an electronic guy check the speedo circuit and found a cut off cable that leads to the speedometer needle coil...the speedometer begun to work again all right, but there is a fail code leading to the cruise.control ecu says no speed sensor signal...there is a black/red cable that seems to deliver some kinda of signal from the speedometer to the cruise computer, the tcm and de ecu, and again seems there is the problem, no signal or maybe as in your diagram, could it be some kind of problem realted with the ccu ecu and that diode in the computer that is blocking the signal...???
I am guessing the code is from your engine ECU and saying no speed sensor signal. You need an oscilloscope to see the speed signal and verify that it is present. It is a square wave signal proportional to speed. The speed sensor drives the speedometer, and the speedometer drives a transistor that generates the speed signal for the engine ECU, cruise control ECU and diff lock ECU. The wire color you mention don't make sense, the Black/Red wire should be for the park/neutral switch, but I guess you haven't said what year or specific model of 80 series that you have. What year is your 80 series? Is this a U.S. model or a world model? (does it have OBD-II?)
Thanks! The EWD makes no mention of that, I'll have to visit the FSM for those details, hadn't looked there.Just an FYI, CC light flashes for its specific codes. When there is an issue the indicator light will flash just like OBD1, count the flashes and refer to the FSM for those specific codes.
Cheers
... DTC 21, pointing towards that there isnt a signal from the Vss 1. As I said previously, I manage to find the problem with the speedometer needle not working, changed 2 capacitors, another blue one also, checked resistances, and finally the problem lied on one of the speedometer coils that makes the needle move was cut off, dont know why....that was the reason the needle only began working when I revolutioned the engine way to much, now it works properly....
...still there is a DTC 21 code present meaning a lost signal for the cruise control and it does not work. And yes the speedometer should send a square signal to the ecus by a Red/black cable on this 93 model...seems to my there is some kind of missing ground, dont know anymore where to begin checking...any clues...!!! There is no check engine lighting and the lockers are fine, but what worries me most is that the shifting in the automatic transmition its bad even sometimes slipping, for what I read can damage the costly electronic transmition components, so the LC remains parked for more than 5 years unable to find the solution to this car. Thank you for your concerns. SmokingRocks, where can I take a look at your fsm 93-94 material? Thank you
