- Thread starter
- #21
You said that the red circuit with the 68 ohm resistor used to drive the CC alone, so I suspect that the circuit impedance is too low when you add the second branch with another 68 ohm resistor. You could try upping the resistance values. 68 ohms seems like it would sink a lot of current for TTL level signals.
I think it was a 68 ohm resistor can't remember for sure. I thought the same thing last night so thats why I reduced the resistance in my final attempt.
Ok, so I read up on the info provided here:
The simple Zener circuit is the solution for a switch-type speed sensor, but the Land Cruiser uses a Hall-effect sensor instead, needing the transistor circuit to condition the signal.
Your diagram of the combination meter does not show any pull-up resistor (to +12V), so I assume that function is done in the ECU's. The transistor's function is to act as the switch-to-ground like in the NON Hall-effect example.
Very helpful thanks. I'm still trying to find out what the resistor value needs to be....
