OK So as many of you know I replaced my gauge cluster with a fully custom speedhut build. In doing so I ditched the old speedometer, which seems to be one of the only gauges in the combination meter that actually has an output signal needed by the cruise control computer, Trans control unit and ECU.
So I read the diagram and added a resistor between the speed sensor and the output of the combination meter (2 C in the photo below). Now my cruise control works great, and my transmission shifts fine but I still get a code 42 (vehicle speed sensor) from the ECU. The output of the combination meter (2 C) feeds all of the control modules so since the Cruise control is working I know there is a signal in the line.
I'm wondering if I'm getting a code because the output 13 B isn't hooked up to anything. But I can't tell if thats a diode or a transister.
Can anyone explain to me what the combination meter is doing here?
I'd really like to get rid of the code. (Also I'm not sure what the ECU does with the vehicle speed input, timing?)
