After a lot of research and seeing a photo of a Superwinch contractor installed on an older 8472 with the deep metal socket receiver for the control, I decided there must be a way to make mine work. I ended up mounting the contractor in the very upper left hand corner. I had to cut off a potion of the metal flange on the backing plate to be able to raise it and widened the cable hole in the top center of the backing plate. The left side of the contractor is exactly flush with edge of the backing plate. No room for a bolt. I cut off the bolt bracket. I tack welded the remaking edge of the bracket to the backing plate. The right side got a bolt. In this position, the socket in the center of the cover would just barely clear the contractor. It had to be mounted so high, I had to shorten the “A” post on the contractor. It worked!
The cover looks exactly like original equipment. You can also see a support rod I installed some years ago to keep the control cable away from the front of the drum. This was after sucking the cable into the roller fairleads two times! Spot repairs are a pain when you are stuck! The base of the rod is a spring so it is totally flexible and works great. I fabricated the mounting frame to easily pin the winch into the Boss Snowplow brackets on the truck. I seasonally change the attachments.
This thread is great and enabled me to figure this out and wire it up. Thanks to all. I went to order a second contractor from Summit. They don’t sell them anymore. Superwinch has gone out of business.
View attachment 1952635View attachment 1952635
