My Supercharged 2016 Lexus LX 570 (5 Viewers)
WA
So I purchased my 2016 Lexus LX with the goal of supercharging it at some point. After deciding to go with Harrop I pulled the trigger this June and installed the S/C in my garage over a weekend. Needless to say the install was super easy and straightforward especially with an extra set of hands to help. The truck starts, idles and drives perfectly and if I didn't tell you it was supercharged you would never have known! But there is one exception which happens only sometimes at WOT and that was the transmission not shifting fast enough and bouncing the rev limiter or hitting fuel cut right at redline.
So the next step was to find a tuner and get my truck properly tuned right? Wrong.
There was 0 support for 2016+ models due to the ecu... I pestered so many different shops and tuners but the only one I found was VFTuner aka OVTuning and they said that they did "crack" the 2016+ ecu's but I would need to send my ecu out to them in S. Korea to have it unlocked and calibrated so that a tune can be performed. So I bought a 2nd ecu so that while my first one is sent off I could still drive my truck and thank god for that because long story short it took 5 months to get a working ecu back! It was a roller coaster of emotions during those months but I'm glad to have done it because now the truck drives absolutely perfect!
Those of you guys that want to S/C but are hesitant because of the tuning ecu issue no longer need to wait because according to my tuner I am the guinea pig and they are building a good tune file from scratch. So far we have just baselined to make sure the engine isn't going to melt down and fixed the fuel cut and shifting issues. The next session is to see how much power we can extract and the final session will be when I install the stage-2 upgrades (650cc injectors, 80mm pulley) which should be sometime in January.
Here are some pics and vids to keep you guys entertained
Good numbers bud, can't wait to see stage 2 numbers. Your lexs looks great diffently the route I'm going with. Keep us updated. Think there's any advantage for a tune with just bolt on's?
Very nice setup. How do you like it now? Was it worth the cost and headache so far? Enough of an improvement?
Nice success story...I am hoping for the same. I shipped a new ECU to OV tune a few months ago and they say they have cracked it...but went radio silent when I asked them to ship it back. How did they manage shipping for you? Did they want you to buy a tune first or just charge you for the freight? Thx.
Very cool, I see alot of the supercharger content on Tundras, less so on the LC / LX. I'm thinking about one for my Tundra down the road and not sure between the Harrop or the new Magnuson 2650. Looking forward to the stage 2 update!
Thanks I appreciate it! It's been a labor of love lol
The main advantage for getting the tune is to ensure that your motor will last as long as possible by giving you a safety margin for fueling. In my research I've found that running the stage-1 supercharger as is without a tune and just the higher flowing fuel pump/ fpr is indeed possible BUT the margin for error is razor thin. Most tundra guys have reported that the stock injectors are maxed out and run very lean top end, also the other big issue is hitting fuel cut at redline and the transmission shifting super harsh or too slowly.
Now I am loving it and feel it was worth every penny! I truly feel this is how these trucks should have came from the factory. Before the tune I will admit I was feeling let down and remorse because I couldn't really enjoy the increase in power, I didn't want to risk damaging anything and always had to drive cautiously.
Brother the main reason it took 5 months to get my ecu back is precisely that!! I had to send my ecu twice!
Matt is an amazing guy and knows his s*** and I know he's got a lot on his plate but it took every bit of patience to stay calm and wait for him to respond back. He will get back to you eventually so just be patient, usually about 2-3 weeks and he'll pop back on to inform you its been shipped. I was only charged freight which still came out to nearly $900.
I've wanted to supercharge our 2017 LX570 for a couple of years now...
I recently bought a 2004 CL55, made some upgrades and understand what you mean by adding a tune to keep tabs on the margin of safety. With my CL55, the cooling system needed the most attention because Intake Air Temps need to be managed or thats where the risk of damage occurs.
Have you logged IATs on this setup? Whats done for intercooling?
If I keep our LX, it'll likely see a blower but it would be a truck I'd depend on for almost daily duties so it would be tough to run it on a razor wire of reliability LOL
So, awesome news for the Aussies, looks like the Lx570 can be tuned and supercharged now:
I’m in the wrong state, but wonder if this was anyone on the forum?!
I'll just leave this here...
This was my last dyno session over the summer. Currently pushing a tad over 600hp & 620trq at the crank.
Harrop Supercharged Stage-2
80mm pulley
650cc injectors
Walbro 450lph fuel pump
Custom Snivspeed 4.0'' intake pipe
Custom DD exhaust/ muffler delete
Tuned via OTT (Very rich and conservative tune)
3.5'' "fmic" aka heat exchanger on top of Harrop provided HE
80mm pulley
650cc injectors
What were your dyno numbers on this setup?
80mm pulley
650cc injectors
Nice setup. How are you running the charged air through the FMIC before it gets to your motor? Any photos of the plumbing?
I took that to mean he put in a thicker liquid exchanger in front of the Harrop supplied exchanger, but I could be wrong
I took that to mean he put in a thicker liquid cooler in front of the Harrop supplied cooler but I could be wrong
Ah, yes, that would make more sense. I would think you'd just replace the supplied cooler with a larger one instead of adding a second one. But I guess that works too.
Dyno numbers were 470hp & 490trq
Although I believe she had a little more to give because that day was insanely hot for PNW'ers. Ambient was 90* and I literally drove 45 mins to the dyno and we immediately strapped her down and ran, and she was extremely heat soaked. The dyno operator was estimating at least another 20-30hp and trq were left on the table.
And sorry for the confusion regarding the massive Heat Exchanger haha.
Yes I am running both the Harrop supplied HE and the significantly larger FrozenBoost HE that looks like a FMIC lol.
Nice, those are some pretty solid numbers. I would be pretty happy with that result to maintain reliability.
Are you on stock headers and cats? Might be some gains to be made with some long tubes and sport cats.
I commented on this video on YouTube, how cool is it where you can see the AHC “squat down” as the speedo climbs.. very cool..
Great numbers too. My car is currently getting some custom exhaust work done, can you explain what you did to the exhaust, with some photos / videos of sound?
Basically I would love some further information on everything if you have time. What is a OTT tune?
