Builds My new '79 FJ40 build thread (5 Viewers)
Radiator adapter plates were tapped, prepped and painted.
JB Welded the lower heater hard pipe since replacements are no longer available.
I had good success doing this on my 60. Hope this turns out as good.
Thanks. Good to know.
I just used what I had in the pantry.
I used the same vinegar when I flushed the 2F in my 60 last year to good results.
My coolant wasn't too bad. The block drain was the worst and was likely never cleaned out based on a previous post.
It looks like the water pump had been replaced at some point as it looked newer and most of the hoses had been previously replaced.
However, I will run it all through a strainer to check for sediment and rust debris. If it's crudy, I'll grab some 30% and repeat.
I suffer from "while your in there-itis"
Swapped out my bad 40 AC compressor (shown still installed) for a good used 60 one.
Swapped out the fuel filter since I had easy access to it with a taller 60 series filter.
It was time, it was NASTY. Looks like cleaning or replacing the fuel tank will be my next project.
I gave away my spare 60 series fuel filter to a new Landcruiser owner at the Relic Run who needed one and the cruiser gods repaid my karma with a free filter from Toyota Matt, with my last order, thanks!
You also made him install it then and there!! :lol:
